Few questions before supercharger goes on
Car: 1987 Trans AM
Engine: Twin Turbo 6.0 LS2
Hey guys, got myself a Eaton M90 supercharger that i'm going to throw on the old 305 in a draw through until it finally blows (i know i'll probably only see the good side of 5psi)
I can create all brackets and everything myself, and i know how i'm going to bolt it down and spin it.
The car is a carbed CCC-Qjet which i havent seen anyone SC yet (maybe i'm just blind.) One of the issues is being a mechanical FP it only pushes 6-7psi to the carb. I know i need a boost refrence FPR to increase fuel pressure under boost conditions, however. Does the FPR increase the fuel pressure itself? Or do i need to switch to an electric fuel pump in order to increase the fuel pressure? Or will the FPR act as a "accelerator pump" and increase the 6-7psi to 8+
The other question would most likley be more suited for the carb section.
The CCC-Qjet tunes based on vac and tps sensors in a rudimentary SD style system. How will the VAC sensor display boost? Is it capable of showing positive pressure? What will the ECM do since it does have a positive pressure in its MAP?
Other than that, i got everything layed out. Should be fun!
Thanks guys
Thanks guys
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: Few questions before supercharger goes on
Weiand used to sell blower kits that worked with the CCC carb set up and was smog legal. You may want to do a bit more research....
Car: 83Z28 HO
Sorry - double post...
toronto formula
11-10-2015 06:17 AM
