do i need bigger fuel line?
Old 05-04-2009, 10:31 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
I am installing a 100hp nitrous plate kit. The system uses twin fuel pumps, do i need to upgrade to a 1/2 inch fuel line to supply both pumps or will 3/8 suffice?
Old 05-04-2009, 12:17 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Re: do i need bigger fuel line?
Really depends on the rest of your setup. How much power are you making without the nitrous? Also running 2 fuel pumps off the same line seems kind of inefficient.... Why not just run a small fuel cell for the nitrous? or upgrade to 1/2" line and a good pump with 2 regulators.
Old 05-05-2009, 07:30 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
According to Holley:
Fuel line size is important with EFI, but there is a tendency to oversize feed lines. A high pressure EFI system does not need the same size lines as a low-pressure carbureted engine. A 3/8" diameter line (-6 AN) line is adequate for engines to at least 750 HP. This is a conservative number. A ½" diameter line (-8) line should be used on engines over 750 HP.
Old 05-05-2009, 12:35 PM
TGO - 10 Year Member
Street Lethal's Avatar
3/8's will be fine....
Old 05-07-2009, 12:28 AM
82Five-O's Avatar
Car: 82 Sport coupe
Great idea, ill go for the 1/2line upgrade and good pump with two regulators. Thanks man. I guess i over-engineered that one.
Frozer!!!
01-19-2024 04:55 PM
theshackle
03-05-2017 06:37 PM
Andrew6.688
12-13-2015 10:59 AM
AkDrifted
08-17-2015 07:45 PM
Quick Reply: do i need bigger fuel line?
