Which carb hat?
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Re: Which carb hat?
I run the low pro procharger hat. I am having problems tuning my car cause of it. Hats make a huge difference in how the car acts. If i were to do it Again i would go with the EV hat. I am buying one here soon. Not what you wanted to here but its the truth. The low pro hat will work and if you could get away with running the spacer would be your best bet.
Car: 85 Trans Am / 64 Chevy Nova
Engine: Turbocharged 355ci / 383ci
Transmission: WC T-5 / T10
Axle/Gears: 3.45 / 4.11
Re: Which carb hat?
the ev is good but so is the spectre low profile, i was running it and I like it alot its just you gotta get adapters if your not running 4 inch intake piping
Re: Which carb hat?
I know this sounds stupid but there are some really fast GN's that claim they got rid of turbo surge by putting those stupid Tornados in the MAF tubes. Wonder if the same thing in front of the carb hat might improve the air flow through the low profile hats. Yea I know
Re: Which carb hat?
ProCharger's low-profile carb hat is only 2" tall. Their taller carb hats are only 2.75" tall. The taller the hat is, the more time the air has to straighten out before going in to the carb, making it easier to tune.
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
Engine: LC9 , LT1
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Re: Which carb hat?
The EV hat is great, but I have heard that for 8-10 psi, the spectre hat is fine and tuning isn't a problem.
One guy is going 119 mph in the 1/8 with this hat.....$69 at pepboys?
RedLeader289
05-28-2019 01:47 PM
efiguy
09-27-2015 01:30 PM
