Twin Turbo V6 2.8L Camaro
Car: 1982 Camaro Sport Coupe, 1989 GTA
Engine: 355Ci, None
Transmission: B&M 700R4, 700R4
Axle/Gears: Stock, Stock Borg-Warner
OK, instead of putting one big turbo on my 2.8L 1985 Camaro, and getting a lot of turbo lag, i want to put two small turbos on it so that they both spool faster and i can get some good boost. I was wondering if anyone could point me in the direction of information that is up-to-date. I tried looking at the stickies but they are pretty old. I did find some useful information on them though.
I am looking to do a JY/DIY twin turbo setup. The only thing is that i dont really know how much these 2.8L V6's can handle and i dont want to destroy my car. I need information on the constuction of it, the items needed, i know i need a wastegate, the turbos, hoses, an intercooler, but after that it starts getting foggier. I am not going to race this car, except mabye the little punk down the street who thinks his muffler tip and body kit makes his car go faster.
My dad and i are going to fix this car up at his house (Southern USA), and i havent seen the car yet because i am at my house (Northern USA). My dad has been welding since he was 13 and has incredible knowlegde of the internal combustion engine. However he has never really fiddled with turbos and twin turbos.
So if i could be gentle pointed in the direction of some resources, or just your personal knowledge that would be great. I have been researching this Via Google and this forum for a day now, so i have some idea what im talkin about, but not as much as i hope to know when you all are done helping me.![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
Re: Twin Turbo V6 2.8L Camaro
1 Post
Car: 1990
Axle/Gears: stock
actually you would use a small turbo with a larger one. the small spins faster and the power is almost instant and then the larger kicks in and you have full power. i think that is how the vett does it.
but i have never used them so i may be wrong about all that.
if you use the search button here you will find more than 11 pages of links on that topic.
good hunting.
good hunting.
Engine: 355Ci, None
First of all, thank you both for not flaming me!![nod](https://www.thirdgen.org/forums/images/smilies/nod.gif)
I did not use search, which i should have, i looked at the sticky and a couple other post and found a lot of old out dated links, so i said enough ill just make a thread.(newbie mistake i guess).
The motor is a 2.8L not a 3.1L, but i may very well get a 305/350 and do it. The only thing is that im not trying to dump gallons upon gallons of fuel into the motor until i want to really go.
The big one little one idea is actully really good, ill have to talk that over with my dad. Do you think a 305 and a turbo 350 trans would be able to hold a good amount of boost? Im not really aiming for like 500rwHp, i just want to be pretty fast, but im also 17 and have VERY limited funds.
i have three motors and three transmissions in question, the 2.8L, 305, and 350. And the stock 1985 sport coupe trans, 350 turbo trams, and 700R4 trans. Which setup do you all think would be cheapest and most effective?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
If you are not looking for 500hp then I think you really don't need to twin turbo charge it. It sounds a little overkill. I actually think the idea of getting a T-Type or GN motor and doing a swap would be a much much better idea. Then engine is already setup for the turbo. You might have a few conversions to do, just ensure you get the computer and the wiring harness.
1 Post
Car: 1990
Axle/Gears: stock
go to a vett board - not sure which one - but it was there that i saw the big little setup. it might even be standard for them, not sure. but it was on the vett that i saw the setup.
and if vett has it - then gm probably designed it.
also look on ebay for dual setups. not to buy - but just to see what is out there. your probably dont want to get some junk off ebay. you want to be able to look at it - it will be spinning pretty fast and you want to see the quality.
Engine: 355Ci, None
That is called a sequential setup BTW. I will look into those motors. Really i think i just want a twin turbo to say i have it. And beast my friend in his car. he has a fourth gen.![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
and because people will look at my V6 and be like ok, thats cool. then ill just rip the tires and smoke their asses
ps dnt mind the 0's my o key barley w0rks lma0
u d0 n0t need t0 d0 twins, a single sized prperly will sp00l up fast and make g00d p0wer.
a single t3/t4 hybrid with an ar 0f .63 n the hotside will s00l fast and be cabable 0f making 400 hp.
and was the first turb0 i ran on my 2.8
my new v6 put d0wn 268rwhp and 370 rw tq @ 10psi with a t3/t61 @ 10 psi with a messed up ignition system i.e i only had 8* of ttal ignitin timming and it still put d0wn th0se numbers
any ?'s just ask
any ?'s just ask
Engine: 355Ci, None
any ?'s just ask
any ?'s just ask
and i have some knowledge but not much.
please explain this. i understand the spooling thing, but not the technical junk that seems so pivitol lol. Will my 1985 2.8L motor be able to handle all that? 400rwhp is alot, but im not going to be using it all the time. how bad will this beat down the motor?
u have an 85 motor ? thats a carbed motor isnt it? if it is i wouldn't touch it with a 10 ft p0le, the earlier motors carbed have a small journal crankshaft and are very weak.
a stock v6 m0t0r (fuel injected ones) can handle 400 hp and spin upto 7k rpms without issues
Engine: 355Ci, None
And i dont understand exactly what turbo im looking for. ive only been learning this for a day, and i dont want to be too annoying, but i just dont know.
yeah the ? is hw much money do u want to spend, u want ebay stuff or do u want brand name stuff.
if u lok in the v6 section i have a sticky at the top that shws my first diy/jy style build
Engine: 355Ci, None
are you daves12secv6? i think it was????
Engine: 355Ci, None
Your thread is what i was goin to use to assemble it.
I would like brand name but i have like no money, so im going with the cheapest effective system possible.
Engine: 355Ci, None
via Wikipedia "The 2.8 V6 became fuel-injected, raising power from 112 hp (84 kW) to 135 hp (101 kW)." about the 1985 camaro
http://en.wikipedia.org/wiki/Third-g...et_Camaro#1985
so there it is, it must be fuel injected. How much RWHP did you get with that sticky thread setup? like i siad i just want to be able to beat down the random snot nose kid whose mommy and daddy bought their eclipse, body kit, and muffler tip that magically gives more HP. 450RWHP is cool, but just uneeded for me for this car. My I-ROC im going to buy after this one, thatone is going to be a monster.
just f0ll0w that thread, and pst any ?'s u have in it.
i dnt knw powerwise i never had that setup dynoed,but its way more then enough to beat up n some h0ndas, gt mustangs etcs
Engine: 355Ci, None
awesome, right now i am looking up the parts. I have never seen the engine, nor has my father, so im really hoping that my engine is in good enough shape. would that set up be that same pretty much for a 305? will my 24 year old stock trans be ok?
keep the bst dwn and u should be ok,but u really need t find ut what cnditin the motor and trans is in first befre u do anything
Engine: 355Ci, None
yeah, my uncle does not seem to be in any hurry to give us pictures... kinda making me mad, actully it really is, because i need to save money for the interior, and i dont even know what in the interior needs fixed...reall bothering me.
I am a compulsive excel speadsheet maker, so i enjoy finding these parts and using excel to tell me my total prices and stuff like that.
I really do thank you for your help, i really do.
and im having trouble finding this: "36mm external gate also off ebay.i recomend getting one with a 3.63 psi spring" i see alot of 35/38MM and 8PSI springs
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
what project is saying it would be better if it is a 2.8 mpfi motor..this might help you out also not meaning to change subject..project would it make any diff to port the heads on the 2.8,,he also gave me the idea to do the turbo on my car
Engine: 355Ci, None
what exactly does mpfi mean? x x fuel injection?
35/ 0r 38 mm gate is fine, the 8 psi spring is fine if thats the lowest u can find. at suck a low boost level u will have a hard time hurting the engine unless it i s seriusly lean on fuel
snow man porting the heads will help,the head sn the 2.8/3.1 and 3.4 rwd mtrs are all the same
Engine: 355Ci, None
OR does that say at suck, which is a low boost level, it will be hard for me to hurt the engine unless i am running really lean. and i found a site with a 3.63, and its only $69.99
Im about to look on just good ol' google and look for the 35mm 3.36psi
Engine: 350 crate
i think he meant to say at such a low boost it wont hurt anything
Car: 1989 Formula
Engine: l98
I found a local parts yard with two turbo grand prix in it. Do some research and let me know what you need.
Engine: 355Ci, None
snow: Thank you, i wasnt sure which one of the two statments that was.
Turbo: is aiken near Charleston? Charleston is where the car will be when we are working on it. Mount Pleasnt Actully.
Engine: 355Ci, None
how does this turbo kit look to you, any opinions??
http://cgi.ebay.com/ebaymotors/Turbo...1%7C240%3A1318
lil expspensinve fr what ur getting cause u w0nt use the manifld, but thats the right turb0 and it c0mes with an internal gate s0 u woulndt have t get a external wastegate
if u l00k arund n ebay u can get the kit cheaper cause it w0nt have the stuff u d0nt need
Engine: 355Ci, None
38MM Wastegate :
All Stainless Steel hardware, Mating weld flanges are 304L.
Spring Size is 7 PSI.
how hard is it to change that spring? or can you not even change the spring?
the 7 psi spring is fine, the boost level is so low u wouldnt hurt the motor unless u were seriously lean, 7 psi will run perfect if u swap the stock injectors for 19 pound injectors with th e stock ecm
Car: 84 Z-28, 01.5 Cummins 3500, 98 Ford
Engine: mild 355, built Turbo Diesel
Transmission: th-350
Axle/Gears: soon to be broken, 3.55's in diesel
I run a Industrial Injection 66mm/71mm 14exhaust turbo... but that's on my tow rig, lol.
you can find a holset style turbo super cheap, I sold my hx 35/40 hybrid for 500 bucks.
your looking at major internal work, the T-bird turbo coups had steel cranks and cams and if you turbo'd a say... Ranger motor non turbo they would smoke the sizzle and burn to the ground. i guess same principle.
could you put a lil whipple on there easier?
the factory motor needs no internal work in order to be turbocharged,
stock bottom end motor here making over 300hp and 400ftlbs
Engine: 355Ci, None
ok just got news my engine runs but is in crummy condition, so i will be swapping with a 3.4L i think he also said that i probably have a 200R4 trans, or a 700R4
glad to hear that the 2.8 is such a good motor. in my experience the gassers with turbo's came out with better internals than the S.O counterparts, I was tossing out an idea... i was wrong, thank you for being able to rectify that... calm down... I'm stepping away from your attitude slowly....
Engine: 355Ci, None
bomber, that dude is cool as ****, i believe he was mearly pointing out that you wernt correct in your thought, thats all, he wasnt flaming
the 3.4 is a good swap, u will need to reuse ur 2.8 intake, and front timming cover, u dont have a 2004r its a small bellhousing 700r4
Engine: 355Ci, None
so i have a 700R4, isnt that a pretty raw trans. also this is a 1984, i just found that out aswell. did the 2.8L 1984's not have the gfx and had the nose with the three rectangle slots that just kill the look. i could still use the trans on a 3.4L right?
Hotrodboba400
12-10-2019 07:07 PM
Zeek1041
Theoretical and Street Racing
09-30-2015 11:00 AM
Andrew Prakash
09-08-2015 11:48 AM
