single turbo manifold
Old 03-13-2009, 09:44 PM
  #51
85camarojunkie's Avatar
Car: Camaro coupe
Re: single turbo manifold
Would be a sweet setup. what is the maximum boost out of curiosity on a fresh built 350 (I rebuilt it to standard setup) I think i heard 5-7 on a single turbo setup. does that sound right? Thats on standard rods and pistons.
Old 03-13-2009, 10:07 PM
  #52
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
http://www.theturboforums.com/smf/in...?topic=61219.0
Old 03-14-2009, 12:38 AM
  #53
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Lol, that thread pops up EVERYWHERE. Some of the most interesting stuff I've ever read.
Old 03-14-2009, 10:33 AM
  #54
TGO - 10 Year Member
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
But i dont believe its an indication of what everyone with any motor can achieve... I still think that guy got alittle lucky. Tune is one thing but parts can only hold so much
Old 03-14-2009, 11:27 AM
  #55
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Originally Posted by junkcltr
That pressure sensor is not for the ECM. It provides power to the fuel pump. If that pressure switch breaks open then the fuel pump will not stay on after the engine fires. The ECM just spins the pump during cranking/engine start.
It's actually just a backup in case the fuel pump relay fails. If your fp relay works you can unplug that sensor and the engine will still run. If the fp relay fails that sensor will turn the pump on as soon as it sees pressure.
Old 03-14-2009, 12:55 PM
  #56
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
I dunno, he did a big block too, and others have done it. All Chevy as far as I know. I have heard that cast is actually stronger than forged, but forged handles detonation and rpms better. Cast is brittle and hard, forged is softer and more flexible, right? Kinda like drag gears I guess? Keep the rpms low, try to reduce harsh combustion, no detonation. I dunno, thats a whole thread in its own.
He ran that car for like 3 years, but did break a ring. More gap would've fixed that.
Old 03-14-2009, 02:55 PM
  #57
GodSpeedGTA's Avatar
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
Forged is stronger than cast across the board. Higher tensile strength, toughness, etc...Cast is NOT stronger than forged. Forged has a directional grain structure while cast is completely random.
Just to correct any bad info you recieved. Not trying to be a douche.
Old 03-14-2009, 03:14 PM
  #58
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Well ok, I read that somewhere that was believed to be a reliable source, but I don't remember where.
Old 03-15-2009, 09:23 AM
  #59
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
its 110% in the tune look how much dyno time he has spent tunning.. IN the thread he did mention he seen cap/crank walk. So he just snugged em up a little bit more.
Keep it out of detonation and dont spin the motor too 8k and everything should be fine. Your gradually bringing up boost so Its not gonna be that hard as an initial 300hit of nitrous or anything.
anyway its deff. a good post for everyone to read . Like you said NOT EVERYONE will get those results but no reason anyone cany get over 4--500 rwhp on a l98 with a good tune and boost.
Old 03-15-2009, 11:23 AM
  #60
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
thats why i'm takin my ride to a pro tuner i know when i've got it all put together... someone who knows what they are doing can get you enormous power safely with the right tune.
Old 03-15-2009, 02:45 PM
  #61
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Yea, as long as they actually know what they're doing.
Bubbajones_ya
07-06-2024 08:32 PM
Hotrodboba400
12-10-2019 07:07 PM
tommy z-28
10-06-2015 10:58 PM
customblackbird
10-01-2015 04:30 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: single turbo manifold
