Twin Turbo 400 Buildup- '89 Iroc-Z
Old 10-25-2009, 01:22 PM
  #351
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
Re: Twin Turbo 400 Buildup- '89 Iroc-Z
Good Luck!!!
how come you also replace the front wheels?? are those lighter?
dont forget the camcorder
Old 10-25-2009, 07:27 PM
  #352
TGO - 10 Year Member
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: Strange 12 bolt 3.42
Front wheels are GTO spare wheels with M&H racemaster front runners. They are 17" to clear my C5 brakes which i dont have on the car yet
They are VERY light compared to my stock C6 wheels...and I think lighter than the summer star 15" wheels i had last year
Check out the runs: 10.37 at 134 was my best
https://www.thirdgen.org/forums/orga...ml#post4325669
Old 10-30-2009, 04:20 PM
  #353
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Well did some more tuning and now have boost controller set to 12 psi. Going to bump it again to get 13 and call it a day. That should put me at 800-825 hp on motor. Car feels very strong but runnin abit richer than i want. Going to lean it down a touch more and start desensitizing the knock sensor, as it pulls out 4 deg no matter what timing i have in there.
Old 10-30-2009, 04:45 PM
  #354
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Dude that looks TOUGH with the turbo's showing. I think it would look kinda goofy with two bubbles the the front to cover them. As a bunch of people have said, leave em showin!
Old 11-09-2009, 09:53 PM
  #355
87IROC350's Avatar
Engine: 5.7
What did you do with the pressure sensor(evap system) and charcoal canister on the LS1 tank? Also I'm needing the tube and filler neck for the LS1 tank any suggestions?
Old 11-09-2009, 11:01 PM
  #356
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
left the charcoal canister on the tank. Ditched all of my old evap system. Left the stock LS1 canister vented to air. I used a factory 4th gen rubber hose and metal filler neck, and its just laying in the opening of the gas cap. Works fine for me. Just a hint of gas smell if you leave it parked after long ride but seems to be doing its job, car runs abit rich at times so i smell gas regardless.
For those following that havent seen my latest outing to the track, the car went 10.07 at 137.7 on 12 psi, 10.06 at 139.2 on about 13psi (12.9 on datalogs) and 10.02 at 140.3 on about 14psi (13.8 on datalogs). Pump gas, 93 oct, no meth injection and ok 1.56-1.60 60 foots
https://www.thirdgen.org/forums/orga...ml#post4341343
Old 11-19-2009, 02:50 PM
  #357
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Pics from PRP 11/14/09
Car has been 9.73 at 142 on a higher boost attempt but didnt work out like i expected. I was guessing it would have done 9.5's at 145ish oh well. 9.86 at 141 is best on 14psi pump gas
Old 11-19-2009, 02:55 PM
  #358
AC
AC's Avatar
Car: Used to drive a camaro
Damn Orr, congrats on the 9's. Awesome DIY build. You're sticking with the $59 for this right?
Old 11-19-2009, 04:11 PM
  #359
Dude, that is haulin' the mail!
AND
you know its got more in it. Awesome!
Old 11-19-2009, 04:13 PM
  #360
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I'm gonna use the $59 as long as i can until i feel necessary to change over to sequential... I think this system is more than fine for 1000hp. Seems to be good for my estimate 800-850 so far and I do plan to hit 1000 crank hp with it someday. If I go for more then I may go to a whole different turbo setup and management anyway to ensure best distribution of air and fuel to all cylinders. Right now I only monitor 1 bank and have not been able to check both sides for air fuel or individual cylinders like I really wanted to.
Old 11-19-2009, 06:00 PM
  #361
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"I do plan to hit 1000 crank hp with it someday."
Looks like you are going to give the Dart SHP block a real workout and see how good Carl's work is.
Old 11-19-2009, 07:00 PM
  #362
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
Just awesome man.. and still on a stock ECM and a stock 10 bolt LOL.
Did that intercooler fit up front by just unbolting the crash bar or did you have to cut off the ends of the frame rails? Did you have to trim any of the nose skin? I've got a guy dropping off an ATI FMIC tomorrow morning that I'm might buy it if looks like it will fit mine.
steve
Old 11-19-2009, 09:22 PM
  #363
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
steve
It fits fine with room to spare under the nose skin. I just cut the crash bar off between the frame rails and welded mounting tabs for the cooler. There are pics somewhere in this thread
Old 11-19-2009, 09:25 PM
  #364
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Yeah, he did do a great job with the machining so i'm confident the block is strong. As long as i keep the tune safe it should handle that power just fine as i'm not really spinning this motor high at all. I figured I've been close to 900 crank already so only a few more psi away from being called 1000hp. Need to get on a dyno and start tuning it. Hope to discover how much psi 93 octane can handle with no meth. I think it can do 16 just fine as its seen 15.5 by accident with no signs of problems that I can tell.
Old 11-20-2009, 12:25 AM
  #365
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Do you fell that cutting it affected the chassie some?
Old 11-20-2009, 05:35 AM
  #366
UR50SLO's Avatar
Car: 86 Turbo Camaro
Engine: 427LSX
Transmission: 4L80E
Axle/Gears: 9" 3:25
The more I look at the turbo's hanging out of the hood the more I like it.
It looks mean as hell... I'm thinking clean up the edges and paint it... leave the turbo's
hang'n out .. I like it
And great runs!
~Scott
Old 11-20-2009, 06:35 AM
  #367
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
It may have made the front noise twist abit more as I cut the top of the rad support off too. WHen I did that I saw the left and ride sides no longer match up. I did put a small piece of metal to brace and realign that top rad support but not sure how much it actually helps.
Thanks, thats what i'm thinking. Gonna clean up the cuts and try to form it closer to the shape of the turbo as i can and leave it at that for now
Old 11-20-2009, 02:20 PM
  #368
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
man the car looks great!!! nice work.
Old 11-23-2009, 12:00 PM
  #369
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
very kool i've been talking about this left and right to all kinds of people. Definetly inspiring .......... a streetable 9 second fuel injected car has to be just to much fun, if it start getting too rough on you, you can always give it to me haha.
btw very nice fab work, better yet beautiful car.
Old 11-24-2009, 11:57 AM
  #370
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I ran my old 305 on 16 psi with 94 octane and no intercooling. It was an LT1 cam, so hardly any pressure bleeding, but I did have about 7.5:1 compression. It was also carb'd and that cools down the intake a bit, 40* from what I hear. I was only running about 21* timing also.
Motor was all stock and I didn't care if it blew. Are you working on getting a better knock sensor setup? I've noticed some speckling on my plugs with 9 psi, leaky cam, 93 octane, 28*, but only a 13:1 afr. I was too nervous about using just 93 while playing with my timing and use meth now.
Old 11-24-2009, 02:09 PM
  #371
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Ultimate goal will be to run meth injection but for now I am still working out some bugs.
I dont know what other knock sensor systems there are and to be honest i havent checked my plugs lately.... knock on wood haha but I do notice the computer is pulling 4 degrees during WOT... doesnt seem to matter what my timing is it will still pull timing. I had 110 octane mixed with 93 and it still pulled timing but NO way it could have been knocking/detonating. It was a 50/50 mix 110 to 93 fuel. I mean I think i was at 16.5psi boost with like 18-19 degree if you subtract 4 from the computer and around 10.3 to 1 air fuel ratio. This crap tune still went 9.73 tho. Even on the street after i got home i turned boost back down to 11.5psi and it was still pulling timing.
When i first started tuning 10 psi, it was pulling 4 deg so i bumped down 2 degree in the table and it still pulled 4 so I'm not sure if its sensing false knock from surounding noise?
My current street tune is closer to 11.8 to 1 air fuel at 11-12.5 psi with 22-23 degree timing in the table, ecm pulling 4 deg it says. If the weather stays clear the rest of this week I'm gonna get back up to 14psi to start leaning that out just a touch. It was around 11 to 1 at the track when I ran 9.8's and I want it to be closer to 11.5 to 1. 21 deg timing in the table at that point.
I will be going to the dyno this weekend to get a baseline at 14psi and may try a chip with 2-3 degree less timing than what i have now, and then another chip with 2-3 degree more timing to see if the car picks up anything. Its a dyno day so I may only get 3 pulls.
Local tuning shop told me at 10 psi they would run 21 deg timing I think it was but that seems WAY low to me for 93 oct but I dont know much about tuning for boost. I got 25 degrees or so after 4400 rpm at 10psi.
Old 11-24-2009, 02:42 PM
  #372
bakes85's Avatar
Car: 1985 trans am
Engine: 1969 chevy 350 .060 over
Transmission: 5spd
hey Orr89RocZ, just curiosity here but how much do you think you have spent on your car?
Old 11-24-2009, 04:03 PM
  #373
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Ouch..... That's a dangerous question. If you have to ask it's too much.... hahahah
I'm sure that Orr doesn't even wanna say by this point.....
But please do tell..... Round to the nearest thousand
  #374
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
More than i should have haha thats for sure
Old 11-24-2009, 04:11 PM
  #375
???'s Avatar
i've noticed with the stock settings for timing in 59 that once it pulls timing, it leaving it out for a very long time. which is good for boost when the tune is right, but working with my n/a car i noticed that i had a lean point in AE and it caused it to pull timing, which it held all the way out thru the pull. it had me pulling timing out of the whole rpm band at wot chasing it. once i lowed the amount of time it takes to add timing back in. i figured out is was the AE doing it.
so maybe if you getting a small blip of knock somewhere, it might just be holding it out. i'd be carful with the setting thou. F6 and F7 are how fast it it pulls(i think) and how fast it feeds it back in once knock is gone.
Old 11-24-2009, 04:22 PM
  #376
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
haha
Old 11-24-2009, 04:23 PM
  #377
???'s Avatar
some would say a pump gas street car that can run 9s on mph and not needing a 1.3 60 is priceless
Old 11-24-2009, 04:28 PM
  #378
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
yeah, the fact that it runs on pump gas is pretty awesome
Old 11-24-2009, 04:44 PM
  #379
AC
AC's Avatar
This is the greatest question around here...and I quote the greatest answer " Asking how much we spent on our cars is like asking how big our wifes **** are"....
Old 11-24-2009, 04:50 PM
  #380
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Pics?
Old 11-24-2009, 06:39 PM
  #381
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You know i bet thats what it is... i do have a very rich AE condition I think but do not think its causing the knock. I know my tune is NOT perfect and far from it. I just dont like the idea it holds timing out like that without me having the ability to control how much timing is pulled per rpm like other codes use. That way if it is false knock, i'd beable to control it better by limiting the amount pulled.
I did notice on my burnout on my quick attempt at race gas tune, it pulled as high as 10 degree at one spot, just at the intial throttle stomp to get tires rolling. Not sure why so I think it may be something in there with AE. Can too rich be causing this?
I do agree, its pretty sweet But now i'm greedy to get more ET for my power...speed is a hell of a drug.
I totalled up the turbo build this year and it was interesting how much things added up...but i dont have my list anymore so I"m not sure exactly how much it was
I want to guess it was approaching 15 grand for entire setup from motor to trans to driveshaft to fuel system..but may be abit higher.. this doesnt include the money i spent on interior/roll cage/suspension mods/old 383 which i reused the heads/valvetrain stuff from that motor for this motor I should have bought a C5 Z06 like i wanted
Old 11-24-2009, 06:57 PM
  #382
Car: 1989 GTA
Engine: 369 TPI
For all you have done $15 grand is not bad at all. Doing a lot of the work yourself helps.
Old 11-24-2009, 07:19 PM
  #383
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
I dont want to know what a shop would charge to do this build and tune it................... maybe thats why nelson racing is like 50 grand
Old 11-24-2009, 07:52 PM
  #384
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
yeah, your work amazes me.
Old 11-24-2009, 07:56 PM
  #385
AC
AC's Avatar
Orr, your car and a few other of our cars are all in the priceless range given all the time we've put into them. Your car honestly should be submitted to any of the popular mags like Super Chevy, Camaro Performers, GM Hi-Tech, etc. The ONLY thing that would make your car the cat's *** (IMO) is a T56 or 5 speed built to handle that power
Old 11-24-2009, 08:05 PM
  #386
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
yeah, definitely send into magazines, heck your car should have a 5 page article in Hotrod if you ask me.
Old 11-24-2009, 09:37 PM
  #387
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
And to think i had the T56 laying here.... oh well
Thanks for the compliments but I dont know if its quite magazine worthy...maybe a page in one of them but compared to some of the other cars out there its not quite as impressive
Old 11-24-2009, 09:43 PM
  #388
???'s Avatar
yes to rich can cause knock.. I read a great paper about that, I'll look around for it when I get a min. as for timing, you can have it feed it back in at different times by rpms.
Old 11-24-2009, 09:52 PM
  #389
???'s Avatar
http://www.innovatemotorsports.com/resources/rich.php
Old 11-24-2009, 10:07 PM
  #390
bakes85's Avatar
Car: 1985 trans am
Transmission: 5spd
dude, you dont gotta be modest, just the other day i was reading about the crusher camaro, a 67 camaro with a supercharger, and they were talking about the build,
in my opinion thats nothing compared to the custom work ive seen in your car, like the custom headers and other stuff
Old 11-25-2009, 06:40 AM
  #391
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
the reason i like it is because its something anyone can build in their garage with a cutoff wheel, chop saw and sawzall and a budget welder. Hand fabbed everything and it really wasnt all that bad once you got the hang of it and got the "vision" of what it is suppose to look like
Old 11-25-2009, 11:38 AM
  #392
damn it, i need to get to work on some turbo headers this winter
an old co worker got his 70's monte in super chevy, with a mild 400, 9in and horrible faded yellow paint.
your car is worthy of the cover imo!
Old 11-25-2009, 01:09 PM
  #393
z28freak84's Avatar
Car: 1985 IROC-Z Silver
Engine: Vortec 5.7L
Transmission: WC-T5
Axle/Gears: 3.23 disc brake 10 bolt
MOst DEFINITELY! Remember that old TA with the twins on a stock 350 that went 9's called the GRENADE? That made the cover, and isnt near as nice as ur car.
Old 11-25-2009, 02:02 PM
  #394
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
haha yeah, but 9's on stock 350 is much more impressive and interesting story than a built 400 motor creeping into the 9's Oh well, we'll see what happens.
Old 11-25-2009, 02:24 PM
  #395
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
then pull the 400ci and throw the L98 back in with the Twins!! the 400 can be a back-up bullet. LOL.
Old 11-25-2009, 02:27 PM
  #396
z28freak84's Avatar
Engine: Vortec 5.7L
Transmission: WC-T5
Oh yeah, and there's no reason that you shouldnt be able to run 19-22 psi on 93..and 21-25 on meth.
Old 11-25-2009, 03:42 PM
  #397
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Yeah it was impressive, but he did have a decent cam in it. Keep in mind that he was running C116 and spraying it with a 75 shot to cool it and make it into the 9s. You are doing it with 93 octane from what I read.
Nice build. I would be scared as heck going 9s on a stock rear end though. At least put some C-clip eliminators in.
Old 11-25-2009, 04:03 PM
  #398
AC
AC's Avatar
Old 11-25-2009, 04:05 PM
  #399
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
You think so? I may try 16psi tonight but was afraid that be pushing it on 93 octane and 9 to 1 compression... but i dont have alot of timing in this motor so that helps
Old 11-25-2009, 04:14 PM
  #400
Car: 1989 GTA
Engine: 369 TPI
Justin, are you still running the Mike Jones camshaft?
Quick Reply: Twin Turbo 400 Buildup- '89 Iroc-Z
