87 Iroc LT1 Single Turbo Build
Old 04-24-2009, 07:35 PM
  #51
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Re: 87 Iroc LT1 Single Turbo Build
Well made some good progress, I need to order a Intake elbow then do my cold side, make brakets for the rad, finish the meth etc.
There take her for a haul! Ther pull it all apart for paint lmao.
Jay
Old 04-24-2009, 08:25 PM
  #52
iroc a 86 berli's Avatar
Car: 86 berlinetta 92rs gfx
Engine: 4 bolt 384 stroker
Transmission: th350 4000 stall manual/T brake
Axle/Gears: 87 iroc 9 bolt
looks good, the flange welds look kinda scary but still looks good. id be a lil worried if u heat wrap it all, the welds might crack.
Old 04-25-2009, 07:47 AM
  #53
chevyowner02's Avatar
Car: 1992 camaro
Axle/Gears: 3:73
Looking good I hope after it's done there is going to be a video??
Old 04-25-2009, 08:48 AM
  #54
junkcltr's Avatar
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
An O2 sensor depends on the pressure differential across the element to outside air. Your O2 will not read normal since you have it before the turbo where the exh. pressure is higher. It is recommended to put it after the turbo to read as normal.
That looks like a Holset H2 series unit. How big is the comp. inducer wheel?
Overall, nice job. That is a lot of work doing a turbo setup starting from scratch and making the entire headers/manifolds.
Old 04-25-2009, 11:44 AM
  #55
Jay_rich's Avatar
Car: 1987 Z28
Well the LT1s use 2 o2 sensors one for each bank, that is why they are placed before the turbo. Most LT1 guys do it this way. Also I think the turbo is big enough that I wont have backpressure issues.
The turbo is a Garrett unit from a detroit diesel semi. It is a 74MM turbo. But also a guy on turboforums can turn it into an 88MM so thats next years plans.
Also there will be lots of video dont you worry lol
Jay
Old 05-04-2009, 09:20 PM
  #56
Jay_rich's Avatar
Car: 1987 Z28
All the brakes work! I bled all the brakes and installed the line lock.
Jay
Old 05-04-2009, 09:21 PM
  #57
Jay_rich's Avatar
Car: 1987 Z28
Well the car runs smooth.
I need to finish
-half the cold side
-mallory box wiring
-meth kit
-connect trans lines
-tune
-tune
-tune
Jay
Old 05-06-2009, 09:31 PM
  #58
Jay_rich's Avatar
Car: 1987 Z28
Well cold side done!
Jay
Old 05-07-2009, 08:52 AM
  #59
stupid firewall, can see the latest pics here at work.
off topic, but how did u run that line lock?
Old 05-07-2009, 09:26 AM
  #60
ATK
ATK's Avatar
Subscribing...nice build up!
Old 05-08-2009, 08:19 AM
  #61
Jay_rich's Avatar
Car: 1987 Z28
For the line lock I plugged one of the factory front lines off the distribution block (the one that angles up). Ran one to the line lock then off the line lock I ran a line to a T then split off the each wheel. I ran all new break line everywhere also.
Hopefully tomorrow I will take her around the block if I get a bit more exhaust on it.
Jay
Old 05-08-2009, 08:59 AM
  #62
ahh i see. yea i just bought one, and took a quik look. the fittings are different then the poportioning valve on mine.
dont know if anyone mentioned before, but you cant have your FPR on the firewall if your drag racing at the track.
oh and who needs exhaust, your turbo is enough of a muffler in my book.
a buddy of mine runs twins open down pipe on a 86 capri with a sbf. its way more quite then my N/A stroker with mufflers.
Old 05-08-2009, 12:30 PM
  #63
Jay_rich's Avatar
Car: 1987 Z28
I have had Zero issues at the track, as long as its all braided line you are okay.
I run alot of events around here both NHRA and IHRA rules at the tracks
Jay
Old 05-08-2009, 01:03 PM
  #64
Goosehead's Avatar
You should SERIOUSLY reconsider those welds, im an experienced welder,
ive had a cheap mig welder for years and did the same like you, welding and then grinding them, it looks bad and it IS bad!
There WILL BE lots of very thin spots in the welds and those manifolds/headers will get VERY hot!
They will expand and it will eventually crack, and they might be tiny leaks right now.
buy a small, second hand TIG welder, practice and look at some youtube movies about tig welding, you will get clean leakproof welds that dont need any grinding at all!
Old 05-10-2009, 07:42 PM
  #65
Wrenchp's Avatar
Car: 1988 RS Camaro
Engine: Undetermined
Transmission: TH400
Axle/Gears: Stock
My Friend and I made an LT1 and an LSx system with a mig. that was a year ago. No cracks... no leaks... Same boost level as when it was first made.
Old 05-11-2009, 09:01 AM
  #66
Jay_rich's Avatar
Car: 1987 Z28
Dont know if you read my entire thread...its my first time ever welding...if it cracks I dont really care. Ill fix it. Next year I am gonna make tubulars and just tac them and have a buddy Tig them.
Jay
Old 05-11-2009, 07:15 PM
  #67
jtaj77's Avatar
Nice car.
Old 05-11-2009, 07:33 PM
  #68
bob442's Avatar
just a question, only because i hate how ugly the lt1 altinators are, but wouldnt it have been easier to make a braket and mount the alt. really low instead of having 3 or 4 pointless pullies? i would imagine it would be pretty easy to dream something up, otherwise interesting build, what are you doing for tuning again?
Old 05-12-2009, 08:58 PM
  #69
Jay_rich's Avatar
Car: 1987 Z28
They do make a kit BUT they dont make a kit that moves the alt and keeps power steering, unless u buy a braket and aftermarket pump which I am unsure if it will work in a third gen bc the steering box. Or run vette accessories but I have a 500 dollar balencer and the vette ones are different.
Jay
  #70
Jay_rich's Avatar
Car: 1987 Z28
w000t I finished as much of my DP and exhaust as I could today. I need to go buy a straight length so I can finish the rest!
Also all of a sudden my radio,lights,horn and mirrors dont work so I need to track this issue down! I checked every single fuse etc. They just randomly stopped working all at once. I must of disconnected something that I cannot see.
Also my welding is getting nicer!
Jay
Old 05-12-2009, 09:34 PM
  #71
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
Is the engine painted red or is that Chevy Orange?
Old 05-12-2009, 09:41 PM
  #72
Jay_rich's Avatar
Car: 1987 Z28
It is painted red, i didnt like the looks of the orange in the engine bay.
Jay
Old 05-13-2009, 09:16 AM
  #73
Jay
sweet! i wanna see some vids once she is tuned!!
for the electrical issue, does yours have the main acc power wire on the starter?
Old 05-13-2009, 11:33 AM
  #74
Wrenchp's Avatar
Car: 1988 RS Camaro
Transmission: TH400
Axle/Gears: Stock
Your welding has improved, that down pipe looks good. Sweet build dude, my freinds stock LT1 felt crazy fast on 10 pounds. He pulled it and switched to a 5.3 and turbo right after his LT1 was done though. Now it has been sold (sad day...).
Old 05-13-2009, 11:51 AM
  #75
Jay_rich's Avatar
Car: 1987 Z28
Im gonna check that since i have been reading, when i installed my trans lines i moved the starter wires around, so maybe i pulled one off.
Jay
Old 05-18-2009, 11:25 PM
  #76
Jay_rich's Avatar
Car: 1987 Z28
Well the car drives! It seems pretty hairy! I am using dirtydaveW's timing and fuel charts and it is still lean (13.2 at like 4500 rpm)
SO i think I am running out of fuel pump. (the secondary isnt hooked up yet, I need to finish the mallory box.)
Rolling into it in second gear the car makes about 4psi at 3800rpm and the just smokes the tires down the road lol.
Im gonna get the other fuel pump going and meth and get some tuning in this weekend!
Also I have full exhaust and it sounds like a mild stock LT1 lol
Jay
Old 05-19-2009, 05:59 AM
  #77
jg04222's Avatar
Car: '82 Z-28
Engine: 355
Transmission: TH-400, 8" ATI MRT
Axle/Gears: Moser 9", 4.56's
good job man. i havent followed this thread in a while, so I was suprised when i seen that you have it running.
your 02 sensor placement should be alright; the turbo buicks had their sensors just before the turbo.
as far as your welds go, they could look better, but looks aren't everything. i've seen many welds that don't look like a roll of dimes but are plenty strong. from my experiences with turbocharged systems, your going to have to worry about the tubing that you made the headers out of cracking before the welds (again, turbo buicks were famous for it). any metal with eventually fatigue and crack after enough heat cycles (which, as you know, turbos make a ton of heat on the hot side)...more exotic/expensive materials just prolong the process, and for most it is easer to repair a cheaper manifold than make them out of inconel, hastelloy, etc.
have fun with it man, turbos are a blast.
Old 05-31-2009, 11:42 PM
  #78
Jay_rich's Avatar
Car: 1987 Z28
Anyways so the car is done, i drove it a few times, had some heating issues due to one pusher and one puller fan not cutting it.
Fixed that.
The car is on 5psi, low timing and running rich and it nutty...stomped on it from a 90km roll and roasted them till 140ish.
So i cant wait to tune it!
Jay
Old 06-01-2009, 10:46 AM
  #79
pump it to 10psi, maybe it will stoich out!!
Old 06-07-2009, 03:06 PM
  #80
Jay_rich's Avatar
Car: 1987 Z28
Well i had the car running good on like 7ish PSI, still couldnt tune the pcm, so i ordered new flash chips.
Then the trans blew! First time the car ever went somewhat wot thru a 1-2 shift.
I lost 3rd gear from 2000-5000rpm, and 4th gear.
I picked up a built TH400, pro-brake, 32 sprag, stainless hub, reverse manual valve body! And bought a 3500 stall with anti-ballooning plates.
Im thinking it will be done in a week or so depending on how long a DS takes to get made.
Then the 10 bolt will blow up lol
Jay
Old 06-09-2009, 11:09 AM
  #81
kmo1188's Avatar
I am planning on running my th400 in my '92 RS with the same gear. Id be interested to know what rpms you will turn on the highway and also how you like the brake in the trans? I have an ATI th400 with a transbrake waiting to go in and i cant wait to drive it.
Old 06-11-2009, 02:09 PM
  #82
Jay_rich's Avatar
Car: 1987 Z28
Okay I bolted the convertor to the flexplate to check. Bolts up fine but it overhangs the bottom off the groove for the starter teeth by maybe .100....now to grind or not? It wont be much of each tab so it shouldnt really throw it outta balance.
and here are some pics.
Jay
Some nice shinny POR 20 on the trans!
The nice tiny turbo blanket! its about 2 inches thick inside, also doubles as a great hat!
Old 06-11-2009, 04:27 PM
  #83
got any pics of your clearance issue?
Old 06-11-2009, 06:53 PM
  #84
Jay_rich's Avatar
Car: 1987 Z28
It looks like this (this is someone elses)
Old 06-11-2009, 06:54 PM
  #85
bnoble's Avatar
Car: '91 Firebird Formula
Engine: 383 w/ BW S400 turbo
Transmission: TH400
Axle/Gears: QP 9", 35 spline, spool, 3.15:1
I had a similar problem with my torque converter/flexplate, and I ground the tabs down a little like you mentioned. Not .100, but just enough to give some clearance for the starter snout. I also had to grind down a little of the ring gear to make the teeth flush with the flexplate itself so the converter lugs bolted flat. I think just about every dual pattern converter mounted on a 153 tooth flexplate is going to have clearance issues, as the outer bolts are so close to where the starter snout is.
Old 06-11-2009, 07:06 PM
  #86
well i would grind it a smidge.
but here is a question, is it sitting on a 153 flexplate?
strokers run a external balance crank. unless u went with an aftermarket crank thats internal balance. the ext balance ones utilize the 168 flexplate.
either will work with the right starter, but in your case, bust out the grinder.
Old 06-11-2009, 08:08 PM
  #87
Jay_rich's Avatar
Car: 1987 Z28
ahh okay, yea it seems to sit flat, and it is an internal balenced motor, the flexplate is a TCI.
Ill grind it to be safe. just try to take the same amount off each lol
Jay
Old 06-11-2009, 08:25 PM
  #88
check how the starter engages before putting the tranny in. makes it easier to shim with all that room.
i just swaped stall convertors, not the cause, but wish i would have adressed the flexplate at the time, but shortly after my flexplate died, so i gota pull the tranny out again and replace it! i really hate chevy starters.
well atleast your compression is from boost and not a problem on start up.
Old 06-11-2009, 09:44 PM
  #89
Jay_rich's Avatar
Car: 1987 Z28
Good call Ill hook the starter up tomorrow and see how far it engages. If it goes past the flex plate then i know to grind the converter....I acually my just put it on the lathe and take the tabs down this way it will take even amounts!
Jay
Old 06-11-2009, 10:35 PM
  #90
Jay_rich's Avatar
Car: 1987 Z28
Well i tossed it on a lathe at work and took off an even amount!
Jay
Old 06-12-2009, 12:08 AM
  #91
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
That is a sweeet build! And I love how in the first pic the mustang is behind the Camaro!
Old 06-13-2009, 06:19 AM
  #92
83 Crossfire TA's Avatar
Is your car stock ride height? You said that down pipe is 3.5"? I know my 83 had less than 2.5" clearance under the crossmember, I kept flattening the crossover pipe that went between it and the oil pan... how often are you hitting that?
Old 07-04-2009, 01:05 PM
  #93
Jay_rich's Avatar
Car: 1987 Z28
well i just went for a quick ride, just got video off a blackberry so u cant see too much, but u will get the point.....
Street tires dont work so well, did a few 2nd gear and 3rd gear rolls at low speed and it blew the tires off.
Currently 7psi, 19*timing and like 10.0:1afr NO meth.
So tuning needs to be done.
Jay
Old 07-08-2009, 07:36 PM
  #94
bob442's Avatar
here, get rid of all those pullies
http://storesense1.mysuperpageshosti...s%3AChevy+LT-1
Old 07-08-2009, 11:39 PM
  #95
Jay_rich's Avatar
Car: 1987 Z28
umm they dont make a kit that keeps power steering. Believe me I would if I could, unless i got a Zoops braket and a new pump but then it would run into my hotside.
Jay
Old 07-08-2009, 11:41 PM
  #96
Old 07-09-2009, 12:06 AM
  #97
Jay_rich's Avatar
Car: 1987 Z28
I was thinking the same...all these pics and video and "get rid of those pullies" lol
And here is another quick video, i am running 4 feet of exhaust NO muffler. It ends right at the trans bellhousing, so u cant hear the turbo lol
http://www.youtube.com/watch?v=Hvf2rraOxPU
Jay
Old 07-09-2009, 12:17 AM
  #98
lol, i know, where the hell did that come from.
sounds good, thats a real sleeper! just sounds like a mild lt1.
turbos are kinda like mufflers in a way, id run it like that, or at least straight pipe it to the axle.
Old 07-12-2009, 09:12 PM
  #99
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Nice car! That's quite a bit of work but well worth it, once the beast is properly tuned and all kinks are worked out. Boost on a V-8 is great, but so is a built n/a V-8 that makes 700 hp. Right now, I'd take either.
Old 07-13-2009, 02:15 PM
  #100
TurboedTPI's Avatar
Car: 92 Formula 350
Engine: L98 with a T-76
Transmission: ArtCarr 700-R4
Axle/Gears: Bone stock 10bolt and 3.23's
700hp N/A V-8 or a 700hp Turbo V-8, either one is awesome, but the smooth pull of a turbo car is the greatest feeling in the world. Plus drivability is great (with good tuning of course)
Quick Reply: 87 Iroc LT1 Single Turbo Build
