Good junkyard turbo?
Old 12-26-2008 | 04:02 PM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
I'm looking for a cheap single turbo to install on my friend's mustang. It's going to be a rear mount, 6 psi or so. Trying to help him make his car a worthy contender of mine. I've heard the ones from some of the diesel trucks can work. Anybody know which ones?
The next expensive piece is the oil return pump. Are there any types of fuel pumps that can handle the high temps?
Old 12-27-2008 | 02:23 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Re: Good junkyard turbo?
http://www.theturboforums.com/smf/index.php
Im sure you can find someone over there with a rear mount mustang to answer all your questions.
spend the $ on a good pump. worth it in the long run.
Old 12-27-2008 | 05:25 PM
RedHawkLB9's Avatar
Car: 89 Formy
Engine: carbed 355ci
Transmission: A4
Axle/Gears: 3.73 10 Bolt
i would Not skimp out on a turbo..buy something that will last
Terrell351
06-13-2021 02:13 PM
BlueIroc-Z
06-09-2019 04:22 AM
PestilenceIV
08-20-2015 04:32 PM
ZONES89RS
South Central
08-14-2015 10:07 PM
matthew911
08-12-2015 10:38 AM
