which one of these supercharger is better?
Car: 85 camaro z28
Transmission: auto to manaul
which one of these supercharger is better, the procharger or the vortec? can they both make the same amount of bost? is it better that the oil is contained in the supercharger or external
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: which one of these supercharger is better?
I prefer Procharger, obviously, but either one appropriately sized I'm sure will do close to the same. I like not worrying about the oil coming from the motor as well as not having to do the work for that.
Car: 85 camaro z28
would u say that if its engine oil cool it would keep the supercharger cooler
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
I doubt it, I know my blower and bracket holding it get too hot to touch and I don't see even ambient air temperature oil helping that much to make a noticeable difference.
1 Post
Car: 92 trans am clone
Engine: LO3
Id say go with procharger like said above since its self contained and will produce similar numbers. After what i saw earlier this year i wouldnt run and oil line to my pan or whatever my friend had it with a vortech he shredded his belt and it ripped the oil line out of his $300+ oil pan and the oil sprayed everywhere and he lost it all.
Car: 1985 Camaro Sport Coupe
Engine: Twin Turbo crate 350
Transmission: TH350
Axle/Gears: still workin on that
or........you could go with twin turbos
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
procharger is by far the best. but if you just want low hp then the vortec is cheaper
Car: 87 IROC Z-28
Engine: 406-Mini Ram-AFR 195's-DFI Gen 6.32
Transmission: 700-R4 w/Art Carr converter
Axle/Gears: 9" - 31 spline - 3:89
I have been doing a good bit of research on superchargers as I am seriously considering purchasing one. The Procharger is what I 'm leaning toward. The P1-SC and D1-SC are both self contained head units, no need to tap into the oil pan. Just have to change the oil in it every 6000 miles and the P1-SC can produce up to 800HP.
Car: 85 camaro z28
procharger seems like the way to go. wat type of oil does it take, and wats the price of the oil
1 Post
Car: 1990
Axle/Gears: stock
I like paxton and they made a lot of superchargers just for 3rd gens and they are still around.
you can get them complete on ebay - about twice a year, for less than 1500.00 i just let one pass me by for 1025 and i am so pissed at myself for doing it.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
i like mine two i did not get on the bus like every one else.
toronto formula
11-10-2015 06:17 AM
