Roots style supercharger
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
i was wondering is there any roots style superchrger useing fuel injection not carbs ??
Car: Camaro LT
Transmission: 700r-4
Re: Roots style supercharger
I have seen somewhere in net 454 with dual tbi setup on root style blower and Megasquirt as ECU was used.
propably on msefi.com forum (really dont remember)
PS best regards for You from Latvia, also EU
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
look at eaton blowers and magnacharger i beleive makes them....pretty pricey tho
Theres a few. Just be careful using one that's built for dry flow in a wet flow application or vice versa. A dry flow blower will not usually tolerate wet flow becuase the bearing seals aren't built for it. The other way around (a wet flow blower used only to move air) I'm not sure about- might be OK, might not. Just suggesting that you do some checking if you intend to you use a blower in an application it's not designed for.
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Magnacharger makes a kit with injectors and everything for about $$6500 I think? For either vortec or standard 23* heads..
@Morit - You know i can't loose with Face
@All others - thanks alot for help !!
best regards
best regards
Car: Firebird 88
Engine: 406
Transmission: th400
Axle/Gears: 3.50
No problem there, just a simple LS1, yours should be faster even now..
Especially with new suspension etc..
will see, by now i'm just compileing to be ready it happenes by any chance that he will be faster
Car: 91 GTA
Engine: 377ci
Axle/Gears: QP Ford 9" 3.70s
https://www.thirdgen.org/forums/atta...v-dscf0080.jpg
This is my roots injected blower, but I do not think it is what you are talking about.
Car: 91 GTA
Engine: 377ci
Actually my setup is probably one of my favorite engine out of 4 hot rods I have. It is a 383 with that on top of it. It was easy to tune, and it revs and accelerates like a bunch of made hornets. It is not my fastest car but it is the most fun. It has loads of torque and sc whine under power sounds absolutely great. I think the fuel cooling fight the detonation very well, as I have never had any real problems, even on the hottest of days.
