twin turbo compressor surge at part throttle- but only one turbo
i got the turbos back on, but right around 3 psi at part throttle my driver side turbo starts surging unless i lean into the throttle a bit more.
once i get above 5 psi the surge goes away.
i could understand both turbos having compressor surge but only one ???? wtf![](http://www.fullthrottlev6.com/forums/images/smilies/thinking.gif)
u guys have any ideas on why only one turbo would be surging
Car: '82 Sport Coupe/'89 bird/'77 280z
Engine: 355/2.8/L28E(t)
Transmission: TH350/T5/4 spd
Axle/Gears: 3.73/3.42/3.54
Re: twin turbo compressor surge at part throttle- but only one turbo
Possibly a minute manufacturing difference between the two, impeller clearance, cold piping restriction, air filter, etc...
well they are both garrett t3 50 trims and they spec out identical .48.42's the wheels are the same sizes.same sized wastegates and springs.
no air filters yet im just running screens on the inlets.
i have both turbo outlets y'ed into on 3 inch pipe, but one has alonger section before the y then the other .
i wonder if i switched the turbos from side to side if that would do anything, then if the same turbo surges on the other side i quess that would be a turbo issue then
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I would test the wastegate actuators. Maybe one has a tear in the diaphram. That would cause the surge. Also, check for a leaking header gasket.
one wastegate was opening at 2 psi higher then the other. im gonna try shimming the one springs to see if i cant make up the difference in it.
going to twins has been nothing but a headache so far,almost thinking about selling off both 50 trims and just buying a dam gt35r with an ported s cover or a gt4088
1 Post
Engine: 3xx ci tubo
How can you tell that only one turbo is in surge? By sound?
yeah just going by sound, it was deff only coming from one side
headers dont apear to have any leaks, but i am using dissimilar headers as far as primary lenght so i wonder if thats causing an issue
1 Post
Engine: 3xx ci tubo
Not sure what to say. If it were mine, I would try disconnecting the wastegate lines (and cap them) to the compressor side. Take it for a ride and control boost using the throttle and bring it up to 3 PSI and see if the wastegates are causing the problem or something on the cold side (BOV, connections, etc).
wastegate issue, i threw back on the crossover tube and the old single turbo, and swaped wastegates. i was way off, the 2 psi diff is were they started to crack open, full open on one was 7 psi and the other was 10 psi
LT1Formula
20
11-14-2015 12:02 AM
