Nitrous Troubleshooting
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Took my 92 RS to Cecil County Dragway last night and was quite disappointed. Car is set up for ~140 shot of nitrous. Last time the car was run with nitrous it was set up for ~100 shot back in May and ran a 12.99. Made my first pass, car ran a 14.4, keep in mind it runs a 13.7 on motor. Made my second pass, a slight improvement but still no gain whatsoever. Also detonation occurred at about half track. Came to the conclusion that motor was getting no fuel from fuel solenoid, nitrous solenoid working fine. Would these symptoms confirm lack of fuel in the system? Suggestions?
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
Re: Nitrous Troubleshooting
first of all, whats the specs on the motor? how is your fuel system setup(pump, feed/return line size etc)? and is fuel injected or carbureted? sounds to me like that step up to the 140 shot have pushed or is pushing your fuel system to its limits.
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Car has a 350 vorte c TBI motor. Injectors were upgraded. Nitrous jetting being used is reccommended in owners manual. Fuel system should be adequite.
well if YOU say its adequate then it is, good luck.
Car: '82 Z28
If I'm reading this right... You ran slower while trying to use the nitrous? What nitrous kit are you using?
Car: '82 Z28
I would think it's the other way around if it slowed down. Little to No nitrous flowing but you're drowning the engine out with extra fuel causing you to go slower. You'd go way lean if no extra fuel was going in.
Car: 92RS
Engine: LQ4
Transmission: 4L80E
hahaha nope. But im sure as hell trying!
and i also suspected no nitrous flow going to the plate but i know for a fact that it is going in the motor. Bottled weighed less after a couple passes of this and the exit line of the solenoid was disconnected and nitrous was activated to make sure it was working properly. The fuel solenoid, however, has no fuel in or out.
Car: '82 Z28
That's a strange one then. So no fuel is getting to the solenoid? Is the fuel solenoid clicking when activated? It's just a simple T into the fuel line right? Got a clog or something going on.
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
the only way the car would go slower would be too much fuel. because if the solonid for nos was open all the way with no fuel your motor would have 8 holes in it . the detonation you had was proably a too rich mixture.
I can bet 100 dollars your nos solonid is opening then shutting or not opening fully. ive had 3 nos cheaters do this and is why i switched to big shot noids. beleive me if it was no fuel you would be telling us a different story.
Car: 92RS
Engine: LQ4
Transmission: 4L80E
EDIT* - Pulled a few plugs out today and they were white as snow. Car was running wayyy lean.
Car: '82 Z28
Start tracing stuff back in the fuel line to see why nothing is getting through. Really strange that nothing is even getting TO the solenoid.
Car: 92RS
Engine: LQ4
Transmission: 4L80E
yeah. I think that when the fuel supply hole was drilled and tapped into the TBI some metal shavings were left inside, clogging up the inlet fitting.
CarGuyDennis
137
12-06-2016 11:02 PM
FlyinLow89
11-12-2001 02:35 AM
vortech305
03-30-2001 12:21 PM
