twin turbo iroc
Old 09-23-2008 | 07:39 PM
animusstevo's Avatar
twin turbo iroc
i have an 87 iroc with a 305 tpi and i am currently building a twin turbo 350 , i'm following callaways c4 vette specs but i'm trying to build alittle better. i'm gonna run iron heads instead of aluminum though and i know i need to end up with 7.5:1 compression and around 80cc combustion chambers on the heads but i can't find cam duration or crank and piston specs but i did hear they used lt1 connecting rods ,i also got a truck block 350 like they said and had it turned from a 2 bolt to a 4 bolt splayed . if anyone can help it would be greatly appreciated. just to give you an idea of what i'm doing i'm taking an iroc camaro and making it look like gm cared as much about it as they did the corvette back then so i want it to look like a factory car just with all the trimmings not so much a sleeper more like a tribute to all third gen cars that i think are the best cars ever made
Old 09-23-2008 | 08:47 PM
mesterz2889's Avatar
Re: twin turbo iroc
be sure to post pics
Old 09-23-2008 | 11:43 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Re: twin turbo iroc
Ah I think you could up the compression to like 8.5 even though your running iron heads.
bjpotter
01-22-2019 01:27 PM
1986Z28OWNER
12-13-2015 11:19 PM
PestilenceIV
08-20-2015 04:32 PM
PestilenceIV
08-20-2015 03:33 AM
mustangman65_79
08-11-2015 04:17 PM
