7psi + 150 wet shot bad idea?
it was kinda an impulse buy but i figure at 7 psi it can handle the 150 shot, i mean i did build this thing to take upwards of 25 psi
basically its setup as follows
twin walboro 255's
8.5-1 cr
kb hypers /w plasma moly rings
lightened crank
stock rods arp bolts
42# injectors /w 65 psi base fp
though it is a wet shot so fueling shouldnt be an issue
car makes ruffly 300rwhp at 7 psi +/- a lil bit
u guys think 150 shot would be safe at 7 psi of boost or should i back it off to say 75/100 shot
its an n.o.s. brand nitrous kit if it matters
twin walboro 255's
8.5-1 cr
lightened crank
Car: 86 F-Bird
Engine: 2.8L v6
Re: 7psi + 150 wet shot bad idea?
idk about the 150 shot i meen with a turbo a 75 shot will likely add alot more than just 75. If i were you i woul turn the boost way down then hit it with the 75 shot to see how the motor takes it
yeah i know the fact that its turbo increases the shot level just due to the cooling effects but i dont know how much
ill add this though on a 90* night at 7 psi im running like 121* air temps in the traps at the track
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
I'd say run a 75 or 100 shot first see what happens, then go up. make sure your tune isn't overly rich too, or you'll blow the ring lands right off the top of the pistons
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
I would be leary on anything with those hyper pistons. I would start with a 50 shot first. Most guys Ive seen run just use the nitrous to help the turbo spool up off the line if there is any lag.
yeah im deff going to dial it back to like 50 once the large turbo goes on
right now i have 0 lag with the baby turbo well minimal i should say
i just figured i built this thing for high boost hi hp i figured it could take being sprayed in 2,nd and 3rd with only 7psi of boost on it
its more of a ***** and giggles thing really i bet the thing would run liek a bat out of hell on the boost and 150 shot
curious what would 150 shot do to a mid to low 13 sec car?
Car: 1987 IROC
Engine: 350 vortec
usually close to a second. after that its depressing how much more horsepower it takes to go faster should have 9 second LS power by the end of next season though...nitrous is your friend
Car: 92 Camaro Z28
With hyper pistons and stock rods you are asking for trouble with a 150 shot on your 3.1 V6 without the turbo.
and gm rates the factory stuff for 400hp and 7k rpms
Car: 1987 IROC
Engine: 350 vortec
nitrous is a completely different animal, its an IMMEDIATE 150 horsepower, not gradual like the turbo or NA application. it will try to pound the bearings right out. i would start at a 50 and start going up.
the current turbo im running wont go all to high,thast and i figured with the nitrous it be a simple tune just install the right jets and go,maybe even go one or 2 larger on the fuel jet
the real reason for the nitrous is for when i go back to the large turbo the car will need a lil motivation off the line.so i figured ahh what the hell while im at low boost on the lil turbo lets have some fun
Car: 86 F-Bird
Engine: 2.8L v6
Well with the turbo i think the 35 shot becomes around a 50 shot so if i were you i would always use the next size up on the fuel side then go smaller if its too rich.
Car: 1987 IROC
Engine: 350 vortec
rich is not safe. if you're using an NOS system, they already jet rich so leave it alone jet wise. u really need to tune nitrous just like you tune anything else, datalogging with a wideband or reading plugs.
i quess my best bet would be to call up n.o.s's tech line and talk to somone over there and see what they say about it when i actually go do install it
but a am deff gonna jet it back down from the 150 shot prolly start with a 75 shot and see how it does
Car: 1987 IROC
Engine: 350 vortec
yeah, that would be a good idea, if the motor goes rich, it'll collapse the ring lands, let oil in, cause detonation, and then you've got a big mess.
yeah deff dont want to detonate on hyper pistions.
while ive been dialing in my base tune ive kept my ign timming locked out at 10* so far
tom mornning i am going to the dyno to further tune my car and im gonna go ahead and bring the timming back out to 16-18* total
even at 10* the cars putting down right around 300rwhp +/- a lil bit
my low goal is 325rwhp on 7 psi but depending on how far i can tune this thing im thinking 350 rwhp on 7 psi should be atainable
i have a bunch of grand national guys helping me out with my car and there telling me im prolly down 40-60hp cause of all the timing i have pulled out of the motor
CarGuyDennis
137
12-06-2016 11:02 PM
ambainb
04-25-2016 09:21 PM
