Where to buy a Supercharger?
Car: 1985 Trans Am
Engine: 5.0 TPI
Anyone know a site to buy a supercharger for my 1985 trans am 5.0 TPI?
Car: Used to drive a camaro
Re: Where to buy a Supercharger?
I'm sure there are places in your area but I'm not from the area so I'll give you the 2 I'd goto (I received mine from the place in NJ and the RI shop I know pretty well, there both a procharger dealer).
Larocca's in Jersey
Cisco's in Rhode Island
Larocca's in Jersey
http://www.akronhorsepower.biz/
http://www.asscracing.com/
http://store.jandj
http://www.superchargers4less.com/procharger/index.htm
http://www.jdsperformance.com/index.asp?inmake=all
I bought mine here from a member... still in box, polished and saved about $1k...
Also, these systems are for TPI but with serpentine belt system... you have a V belt... may have to change over and place of few accessories...
If you go low boost, you'll have to switch to FORD / Bosch (not Denso!) 24# injectors... The GM don't like pressure from the FMU... or buy correct injectors and let the computer take care of it... www.code59.org
Raf
http://store.jandj
Raf
The 24# injectors can go in the 5.7's with no computer tuning...
But I see you have 5.0 like me... It will need some minor tuning to use the FMU, cuz the 5.0's have 19# injectors, jumping to the 24's is too much to handle without reprogramming...
I plan to do this in a couple months...
It's the lesser expensive route than going the code59 way... I picked up some used 24 injectors for $65... The code59 route, I would need 42# injectors ($350) + Wideband 02 ($150) + 3bar map sensor $80 etc...
I plan to ditch the 305 someday, so when I get a 350 or 383, I'll go the proper route...
www.moates.net for programing stuff, look at the ostrich, or apu1.
Raf
Raf
Depends on your skills...
Got none? Then no... Turbo Kits are not readily available for our cars, but I hear BBS Designs (search on this board) has some nice quality kits...
But it requires more tuning...
I went the supercharger route because the kit is complete with intercooler, etc... & my skill level is LOW when it comes to that sorta stuff
Raf
Raf
Saw this while crusing the baords...
Down a few messages... selling Procharger...
https://www.thirdgen.org/forums/orga...ml#post3861800
fast82z
I've got a 9.94@ 137, and there's another couple tenths left in traction and weight.
__________________
Procharged D-1SC @ 15psi
Procharger kit for sale $3500 CHATV400@aol.com
fast82z
__________________
TinnMann2
Canadian Region
16
06-18-2017 05:10 PM
