What belt sizes do we all run?
Old 07-24-2008, 08:27 PM
AC
AC's Avatar
Car: Used to drive a camaro
For the procharger guys (hell anyone with a serpentine belt blower) could benefit if we had all of us list what we use for the length, rib count and pulley sizes, i.e. I run a P1SC with the 8" crank pulley and 3.70" blower pulley and a 65.5" 8 Rib gatorback. I get belt slip above 4PSI 8(
What do the 8" crank, 3.40" setups use
What other combos do you guys have. List them here so we have a decent reference for existing and future supercharged projects.
Old 07-25-2008, 01:25 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: What belt sizes do we all run?
i have a d1sc w/ the 3.40 pulley setup it's a 64.5 belt but i haven't installed it yet it's sitting in my computer room till my motor's done lol
Old 07-25-2008, 01:21 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
With a 7.65" Crank 12 rib setup this is what I use.
4.00" = 65" (DB650I-12 from procharger)
3.70" = 64.5" (DB645I12 from procharger)
3.40 = 64" (2x 6rib Dayco 5060640)
Now with my 3.4" setup I swapped over my tensioner pulley for something bigger in size to take up more of the stretch of the belts. Seems to work ok but do have belt dust building up.
Old 04-23-2009, 06:05 PM
bearws6's Avatar
Car: 1989 firebird
Engine: 383
Transmission: 6 speed
Axle/Gears: ford 9" 410
F1R 8" crank 4" pulley is a DB645I12
Old 04-23-2009, 07:06 PM
Beater79TA's Avatar
F1A 66 tooth cog on the crank, 45 tooth cog on the blower running a 1600 mm long x 50 mm wide 8 mm cog belt.
Old 04-24-2009, 01:25 PM
sailbrd's Avatar
Still working on mine but close enough for some specs. Seven inch crank pulley, 4 inch blower pulley, 56 inch 12 rib belt. I set mine up so I can adjust the whole blower mount about and inch, then set the tensioner. Will have some pictures soon.
1992 Trans Am
05-10-2023 07:19 PM
eightsixseven
08-14-2015 03:09 PM
Feffman
Mid-West Region
08-13-2015 07:12 AM
knight72
08-10-2015 09:32 PM
scottmoyer
Interior Parts Wanted
08-09-2015 10:18 PM
Quick Reply: What belt sizes do we all run?
