175 HP jet size
Car: 1992 Formula 350
Engine: 5.7 L98
175 HP jet size
Anyone know what size jets to use for a 175 HP shot? This will be used on the TPI 5151 kit (wet). Thanks.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
Re: 175 HP jet size
I'm using 73n-41f, but I have the walbro pump with hot wire kit. You'll have to tune the fuel side to taste.
Engine: 5.7 L98
Re: 175 HP jet size
N2O Jet/Fuel Jet 73/82
I was told this was the size. IS this accurate?
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: 175 HP jet size
TPI = 43psi fuel pressure, carb jetting = 7psi; 78/82 is a 200 shot, will be pig rich, and will probably blow up. 73/44 would be good and safe if you have a nice Walbro fuel pump.
Engine: 5.7 L98
Re: 175 HP jet size
Would the fuel pump be a necessity seeing as how the extra fuel is added right into the TB?
Re: 175 HP jet size
You really need a bigger fuel pump in the tank on these cars if you're planning to spray. The one that came factory just can't keep up with the motor and 175 additional horsepower. Also the pumps are usually old and worn out so it's best to just do it right the first time and upgrade to the Walbro 255lph pump. If you really don't want to go pulling the tank and such you can put a Walbro inline pump inline.
Pac J
05-17-2020 10:44 AM
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
[MN] S&W 8 point rollcage
FueledSoul
09-30-2015 09:18 PM
