is it possible to run a single turbo through a v8?
Car: 92 Camaro RS
Engine: 5.7L 385 Fastburn
Axle/Gears: 9 Bolt 3.70 Gears
I have a T3/T4 hybrid and Im thinking bout suping up a 350 to push the boost. how would i route the exh to go through the turbo exactly?
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Re: is it possible to run a single turbo through a v8?
You would have to get a twin to that turbo you have, chances are it will be far far too small to work worth the time on a V8.
Car: 91 camaro RS
Engine: 350, forged 355 in the works
Transmission: 4 speed goin to th400
Axle/Gears: stock 9bolt, 3.27
just put on the y pipe or somethin and the u can run the oil line from the pressure sender, might have clearence problems but thats nothin
Car: 93 240SX
Engine: LQ9
Might also have problems with the part where the compressor is likely too small as well as the exhaust housing, thus why I said he'd need a 2nd one
Car: 1991 Camaro Z28
Engine: L98 5.7 350 TPI
Transmission: Brand New (again) 700r4
Axle/Gears: GM 10 bolt 7.625 W/ TrueTrac 3.23
I have a T70 on my 350 TPI and that is about as small as I would go on a motor that size. I would go twin of those turbos that you have.
Terrell351
06-13-2021 01:13 PM
