RMT and vortec heads.,
This sounds like a good idea to me and cheap enough. Noone stir me away from a RMT i have don my researching. I just need to know if Vortec heads is a good idea? Also should i stick with a stock cam? I mean what would be a mild cam for a RMT setup?
1 Post
Car: 87 Firebird
Engine: 5.3 76mm
Transmission: Rossler TH400, PTC converter
Axle/Gears: Strange 12bolt, 3.08s
Re: RMT and vortec heads.,
Its a traditional front mount set up with a ballbearing T76, but stock heads/cam will work to support what power you might want on the stock internals. Think about trying to drop that compression, his was 9.5:1 but we had a functioning knock sensor, and ran the 11lbs on 91 octane with 16* at WOT.
Rear mounts can be fun, just make sure you address the oil control issues. Even though STS does not run intercoolers on all set ups, if you can budget it in, i would really consider it, anything to help out that bottom end
gixxer92
05-18-2017 11:20 AM
Chas91Z28
10-22-2015 10:12 AM
monte87cortez
09-26-2015 08:10 PM
