Safe To S/C Stock L98?
Car: 1989 IROC-Z Camaro
Engine: 5.7
I am dumping off my Silverado SS soon, and will be shopping for an L98 GTA.
Is it safe to S/C a stock L98? How much boost can it safely handle? How hard to tune? What kind of power could I expect at "safe" levels of boost?
Whats the best (cheapest) kit for these cars?
I did read through several pages in this forum, alot of the posts seemed tom be for modded/bigger motors, so sorry if these questions are redundant.
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
Re: Safe To S/C Stock L98?
im running a procharger D1SC at 10 lb boost on stock engine (so far so good) and there is no cheap supercharger be prepared too spend money
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Cheapest way is to piece together and fab. a turbo kit. Quickest is to buy an off-the-shelf supercharger kit.
Engine: 5.7
When I said cheap, its all relative. I'd heard anywhere from $3000 to $5000 for these cars. The cheapest thing for my trucks is the Radix, which goes for close to $6000.
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
don't forget what it will cost to tune it properly guess around 500-600 plus fuel system up grades i believe later tpi engines had map instead of maf there may be an advantage there one way or the other on a boosted engine.
Genopsyde
10-07-2015 08:35 PM
adder, boost, cheapest, cost, fbody, l98, power, procharger, roots, safe, stock, supercharge, supercharged, supercharger, tune
