Is an intercooler really needed for <5psi???
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Is an intercooler really needed for <5psi???
I'd say so, especially with the 150HP shot.
Only way way to know I guess, watch the knock count without it.
Besides, what fun is only 5psi?
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
my advice would to be either keep the nitrous on it by itself, or swap out the pistons and put some real boost through it. I have a feeling you'll be disappointed with 5 psi.
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
5psi can make a huge difference with 10:1 compression. friend of mine has a tiburon v6 and he put a roots blower on it. runs 6-8 psi and gained 100whp. he also has 10:1 compression. i run 20+psi on my turbo dodges but they are 8:1 compression.
Car: 91 z28
true, but the amount of timing you'd have to pull just to run pump gas, it would just be more cost effective to just keep the nitrous on there.
FWIW i run about 25psi on mine 9.3:1 and C16
Car: 86 Omni GLHT
Axle/Gears: 3:85
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
If you can do your own fab work, or at least just tack weld it, you should put an intercooler on it. If not, or if its ony a track car, you could just run meth injection.
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Don't know if this helps. I know someone that runs flat tops on a 350ci and 64cc heads that comes out to 9.6 to 10:1 CR. He is running 12 PSI of boost with a carb and no aftercooler or water/alky injection. I told him 8 PSI max., but he wanted more. It has no detonation at 24* timing on 93 octane. It surprises me. Every combo. is different I guess.
Car: 91 rs
Axle/Gears: 3.50 9"
Wow. Kinda walkin the line there. It has to be at least slightly detonating. If the heads have a very good combustion chamber, that would partially explain it. He would make a good bit more power though if he cooled his intake air temps. How long has he been running it that way. You should keep track of that, lol. Let us know when it burns up. Secret scientific test.
1 Post
Engine: 3xx ci tubo
No doubt, I agree. I helped him mod. the dizzy for the 24* max. and told him 8 PSI max.
If it were mine I would not run 12 PSI, but it doesn't detonate. The heads have decent chambers and the quench is small. That probably makes it work.
It is consistenly over-revved also. I don't see it lasting that long. In the 1/4 it runs out of gear. 12.7 ET at 100 MPH in a 3600 lb car......you do the math. It needs another gear or new rear gears.
Terrell351
06-13-2021 01:13 PM
101, 5psi, boost, compression, good, holset, ic, intercool, intercooled, intercooler, intercoolers, irocz, needed, psi, ratio, turbo
