Extreme Velocity Hat
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Are they worth the expense vs performance gained over what is typically supplied with Procharger, Vortech, Wynjammer, etc?
I recently installed a Wynjammer on my stock 92 454SS and it knocked a second off of my ET.
Looks like you guys could easily adapt this to 3rd gens.
www.wynjammer.com
www.wynjammer.com
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
Re: Extreme Velocity Hat
most likely for the power levels you'll be looking at, the $69.99 spectre one from pep boys will work just fine, couple guys on theturboforums.com swear by them and they also tested a/f ratios and they were unchanged between the two. save yourself the money.
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
I have a YS trim that I will eventually be installing on my other truck. I may get the Extreme Velocity hat for that.
What's the best method of sealing the hat to the TB?
I use it with the 1" spacer. From my expierence, much better than stock ATI set up. The stock one only seemed good to about 6 psi. ATI does offer there " tall boy" which is better than the base one. Plus, the EV hat has an o-ring to help seal.
Matt
Matt
Car: 91 z28
the one i was talking about is aluminum pep-boys, autozone or advanced auto should carry them.
Car: 91 z28
yeah, most run the 1" spacer, even with the EV or EV PRO hats.
