Stealth Ram or SLP for boost??
Car: 1988 Iroc-Z and 1985 Z28
Engine: Mild TT 355 and Built 383 Superchar
Transmission: Manual
I cant decide what intake to Upgrade to. Stealth Ram or SLP Runners, Ported plenum and high flow base? I dont want the mini ram pizza box thing.
Tunning is no problem, I am using a Haltech Stand alone.
its a forged 383 with 16LBS of boost and a 150 Shot
Whats your opinions guys? Thanks
Re: Stealth Ram or SLP for boost??
Depends on your goals…. Unless you plan on going _really_ fast with it, one isn’t really going to be faster than the other if you choose the right combination of parts, I would basically go:
- TPI – looks, people are more impressed if you go fast with them, cost…
- SR – ease of maintenence
Thanks. I am just going to go with the slp runners and port the hell out of the plenum for the runners and TB.
Received 1,721 Likes
The MiniRam isn't the "pizza box". That's the SuperRam, the ulimate PITA design.
Here's what the MiniRam looks like. If you're familiar with the LT1, you might notice that the LT1 intake which was introduced a few years later, closely resembles it in many ways.
The more you depend on boost, the less difference the intake system makes to the overall package. You can force ALOT of air through not much runner, with enough squeeze.
That said, the Stealth Ram will out-flow any of the TPI-based systems that use the stock base and long runners. I also think you'll find that it will cost less than the SLP stuff. The MiniRam will outflow them all, but costs quite a bit more; and I doubt the difference in flow would gain you very much, with the boost. When the intake tract is under 2 bar of pressure, minor details in the sizes of things, that might make a HUGE difference at atmospheric, become far less of an issue.
The flow restriction in TPI isn't the plenum; it's the BASE. You'd basically be wasting perfectly good abrasive by messing with the plenum. The payoff, to what little extent there even is a payoff, is in the BASE.
Thanks man. i never took that into consideration. Boost will flow thru anything just the velocity and pressure would change with the different intakes. I will look into a stealth ram because of the price.
thanks
thanks
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
The Holley SR is the best bang for the buck. The LT1/miniram has the shortest runners and highest RPM potential. The SR falls between that and the TPI unit. All will make plenty of power. It just depends on what RPM range you want it at. With the proper cam the SR is a good unit.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
single plane converted with an elbow. Quit messin around.
Yeah. I sold my HSR. I took it to my machinist. He laughed at it and stated "You wont make any power with this". He also said it would cost too much to modify it to fit AFR 210 heads. So... Im buying a Victor EFI intake unless I decide to go blow-thru.
I would love to do the victor efi but the throttle bodies are soo dam much. For the 4-barrel tb its almost $500.00 just for the tb. I think thats too much.
It would make big power over the conventiona efi intakes.
Yeah, N/A the HSR has a limit; maybe 425-450 HP, based on the runner sizes, assuming street compression ratios and pump gas. But at 2 bar (15 psi) and a suitable CR for that, that 450 HP becomes something nearer 650 - 700 HP. ALOT less of an issue. Certainly not worth the difference in cost between the HSR (which lets you re-use a few $$$$ things like your TB) and just about anything else, on a motor as little as a 383. N/A of course would be a WHOLE different matter.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Hmm... I will put AFR210CC on this winter together with my HSR... Whats the problem?
Car: 1991 firebird
Axle/Gears: 10-bolt 3.08
Go with the Stealth Ram. It's not as rpm/flow restricting at the SLP runners. The Stealth Ram is generally good up to 6,500-6,800rpm compared to the modifed stock TPI set-up that's good to maybe 5,600rpm.
I REALLY wanted to use the HSR though. I dont want to spend $$$ modifying something when I can spend less on an intake that will work UNMODIFIED.
And before you all bash my machinist (I know how you org'ers are...), I have spoken to a few well known shops that have used the HSR. One of them said that he had to modify it entirely too much and that he wouldnt use it again, nor would he recommend it to anyone trying to make big HP.
I agree. Now that I have taken a second look, I realize that this intake will probably work GREAT for KillerZ302. It just wont work well for me.
What heads does KillerZ302 have? I was going to run the AFR195's but changed my mind and decided to run AFR210's after having a LOOOONG talk with my machinist. Basically he supports the "spend the money right the first time" theory, if there is such a theory. Considering how much Im spending, I agree with him. A lot of $$$ and a lot of time...
Car: 91 z28
well IIRC some of the HSR's have 1206 ports. Also you dont have to run the carbed style TB if you go with the single plane, a 90* elbow from intakeelbows.com can work with your l98/lt1 style throttle body. Or you can just get a LS1/LS2 pulloff and make it work, not that hard.
Car: Faster
Engine: Than
Transmission: You!
Doesn't some company make an elbow that will bolt to a single plane and allow a twin blade TPI throttle body to be bolted to it?
According to Holley, they dont. I had a recently casted HSR (2/2007 IIRC). My machinist measured it and it neeeded a little grinding just to fit a 1205. I called Holley and they dont even recommend trying to make it fit a 1206. My machinist recommended against it also.
I am thinking about using a Wilson elbow and a 90mm TB. I might go 4-bbl style TB with an EV bonnet.
Decisions...
Car: Faster
Engine: Than
Transmission: You!
It just seems like using the TPI TB may be more cost effective and a little more plug and play (TPS / IAC )...
Car: 91 z28
like i said originally, intakeelbows.com its not listed on their site anymore but call/email arron and you'll get one if you go over to ls1tech.com you see one that was put on an lt1 car. should be on nitrousoutlet.com's gallery as well.
Car: 91 z28
1 Post
Engine: 3xx ci tubo
If a victor intake is used for EFI, why not just make the carb flange adapter elbow with the TB of choice flange on the other end. Anyone actually measure the port length of the Victor Jr. and Stealth Ram intake? You may be surprised what you find.
BTW, posting a pic of an engine does not make it easier to decide which intake is better for it. That is why you end up getting "my machinist said...", "my neighbor's Mom said Victor Jr....".
Posting the cam specs and head specs would be more appropriate.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
I will put on AFR 210cc heads this winter and while I have it apart I thought It could be nice with a new intake.... I have already welded x-tra mtrl on my hsr.....and ported it to 1206......
Cam 227/239 ,560/,577 114lobe
415cui
around 8,7:1
15 psi boost.............
Will investigate Victor jr more...........
/N.
415cui
around 8,7:1
/N.
holley commander is another good option. Easy tunability, and work with TPI setupts for easy plug and play. Just under $900 with the wiring harness. Marty's firebird has be low 9's with a stock 350/tpi and twin turbos. Checkout the gm section on www.theturboforums.com under thread "how long till it grenades?" AWESOME info for those wanting to boost.
Maybe I could use the HSR but after talking to my machinist, I have decided to go with the single-plane instead. The Holley C950 is nice also. I just decided to go with the Electromotive ECU.
1 Post
Engine: 3xx ci tubo
415cui
around 8,7:1
/N.
415cui
around 8,7:1
/N.
1 Post
Engine: 3xx ci tubo
Im familiar with that thread. Very familiar. I even offered Marty my Stealth Ram before I sold it on Ebay.
1 Post
Engine: 3xx ci tubo
A one barrel TB is a lot cheaper than the 4 barrel. If you use the one barrel then you don't need the hat. Take that into consideration when you choose the TB. Even with the cost of the elbow I would think it comes out cheaper going with the EFI one barrel setup.
I will look into that. Im still ordering the short block stuff...
OTOH, the thing is hideously ugly looking a bit like a gift wrapped elephant and there are dozens of ways that they could have designed it better.
Decisions...
Decisions...
I think right now my front runner is the stock style 58mm on an elbow (I’ll make it). It should be the shortest and most likely to fit under the hood plus the elbow gives me a place to experiment with mounting additional injectors.
The funny thing is that it’s not like I really think I’ll need all this, it’s just that although I think that the TPI manifold looks cool, I hate working on an engine with one just because of the extra gaskets and all the extra bolts you have to deal with when touching anything on the top end… so I’m just messing with all this to get rid of that hassle.
no green
01-09-2016 09:22 PM
Royal_Z
09-30-2015 08:45 PM
Dragonsys
09-25-2015 03:51 PM
