how much rwhp from procharger, zz4 and tpi?
I was told that this setup dynoed at about 420-430rwhp through a 700r4 at 7psi. Does this sound about right? Also, that it mph'ed at 121 in the 1/4 mile. Too good to be true or does that sound about right?
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
Re: how much rwhp from procharger, zz4 and tpi?
420rwhp, 120 trap speed sounds right to me. What kind of ET's are you pulling?
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
yep, sounds like its traction limited, 121 should be good for low 11's
Sanjay
08-12-2015 04:41 PM
