TT V6 camaro & TT V6 firebird
figured some of u guys would be interested in these builds
mine >>> https://www.thirdgen.org/forums/v6/4...bo-camaro.html
and Street Lethal's >>>>>
https://www.thirdgen.org/forums/v6/4...ted-trans.html
Car: 89 ws6
Engine: 355 afr195, hsr,gmpp cam, hs rr,
Transmission: t-5
Axle/Gears: 3.08
Re: TT V6 camaro & TT V6 firebird
Cool wish him luck with the project. I wonder how much these v-6's can handle and how long? I am guessing he didn't want turbo's from ssautochrome? haha
i attempted to run my car last night on the single turbo setup,i had just completed the install of megasquirt standalone ems a few hours prior to running the car.
roll the car into the burnout box start my burnout and the motor pulls 1st gear to 7k and i upshift to 2nd motor pulled right to 6,500.i stage the car and bring the motor upto 25-2700 with 4 psi showing.launch and ive got instant 7 psi. pulls right threw first and when i upshift into 2nd and hear the motor pinging right before i could lift it blows the intake pipe off
i notice my duty cycle was over 120% and the car was smoking black so i leaned out the motor a bit.and go up for my second pass
same thing again nice threw the burnout stage the car and leave @ 3k with 5-6 psi this time car rips threw 1st hits 2nd and blows the pipe off again.but atleast it didnt ping and knock this time
i havent had a chance to look at my datalogs from the second pass but the car felt alot stronger threw first.need to get mny battery charger for my laptop so i can see what the data logs say.
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
Lets hope everything is ok. This might be a common question for you but what internals do you have in your motor?
its a bone stock junkyard motor, i have a fully built 3.1 going in the car soon,but im using this junk motor to setup a base tune so i dont have to worry about breaking my new motor.
im just actually very happy i didnt break the driveshaft or the rear with the slicks on the car
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
I'm watching this car with great interest!
About the "laptop charger"...I used to only be able to tune for 15 minutes at a time. That = no good.
On ebay, I bought a kit that comes with a "cigarette lighter->black box->laptop" charger. It also came with a cable for airplane 12v hookups. About $20 before shipping. I searched for "(laptop model) car charger"
Well, I just cut up the airplane cable, mounted the black box(with a zip tie), hardwired it to my car's 12V and voila. Never have a dead lappy in the car again. It'll still draw power(very small amout) even if no lappy is attached, so keep that in mind.
Car: 89 ws6
Transmission: t-5
Axle/Gears: 3.08
Wow that motor is holding up pretty well. Then again I have read and heard of 300hp shot of nitrous on stock 350's that hold up.
I had my car back together last week and had a detonation ping that sounded like a cannon, only hurting a bearing .
I have a pic somewhere of a stock 60* rod shaped like an "S" after water got into the cyl, and the car was still running!
EDIT:
Found them...
http://www.putfile.com/pic.php?img=5496910
http://www.putfile.com/pic.php?img=5496909
1Aauto
Sponsored Vendors
10-19-2016 08:50 AM
1Aauto
Sponsored Vendors
01-15-2016 06:26 AM
1Aauto
Sponsored Vendors
10-13-2015 03:06 PM
Dragonsys
09-25-2015 03:51 PM
