if u were to supercharge a v6 which one would u use
ive been toying with the idea of ditching the twin turbos on the new motor,and just switching out to a centrifugal supercharger.though id still like something i could run high boost with,and i dont know much about the supercharger units.
would a p600b good for a 3.3L v6?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
No. Idk if you changed since NJFBOA but apparently your turbo was off one bank, then u fixed it "ran a 12" and then ran like 21's just build a 350 and spray it. and be done, dont you have a kid/ on the way?
btw, im not trying to be mean,or anything, and id also apreciate it if you looked down one thread and could awser my question, im cranky
![your welcome](https://www.thirdgen.org/forums/images/smilies/welcome.gif)
ROFLMAO
i cant belive any of those guys still belive that,there pics posted in the v6 section as i actually built the whole thing,theres no way i could have ever run it off one bank,rofl
and u mean 21 sec @ 24 mph cause i stalled the car lol
other then that i never did run better then 17.8@106 & 17.0@96 & 17.2@90something that day.I dont even rember anymore id have to dig the slips out.That day i lifted at the 1/8th mile every pass melissa has the video of that day and im positive u can hear the car backfiring and banging from the 1/8 mile out.
lol car was just out at the track last weekend with a stock 2.8 not even a 3.1 100k+ miles on it went into the 15's @ 5-7 psi with a race weight just shy of 4,000 lbs thats around 230 rwhp @ 290 at the motor on a stock untouched high milage engine. with the same exact setup i had at the nats - all the ecm/ign problems
Car: 89 2.8 RS
Engine: the 2.8
Transmission: 700r4 auto
Axle/Gears: stock one wheel squealer
keep one turbo and run an sc too. remote mount the sc and run the turbo to eliminate boost lag and keep high rpm boost. the sc is costly and id say keep the money for now and invest it in your business that your trying to start.
i figure i could sell off ll my turbo stuff and just buy a supercharger head unit.and fab up the bracket/ducting and get away much cheaper then finishing the twin turbo setup
If you’re building something yourself then personally I’m partial to the eaton blowers… just size it for the power level you’re looking for and don’t look back. The nice thing about positive displacement blowers is that you have power wherever you give it throttle, unlike a centrifugal.
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
A guy local to me is doing this to his V6 mustang. I believe its a Cobra sc.
http://www.tcstangs.com/forum/showthread.php?t=49589
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
![yup](https://www.thirdgen.org/forums/images/smilies/yup.gif)
As far as efficiency…, well, yea, they have slightly lower adiabatic efficiency than a comparable turbo (I’m not really sure about most of the centrifugal blowers in that range), but they have killer volumetric efficiency, somewhere in the 90% range, which you’re not going to get with anything but an eaton and some of the screw types. Also, there’s a funny thing with them, as you push them harder, force more boost out of them they get hotter (all superchargers do), as they get hotter the rotor clearances tighten and they get more efficient.
Lastly, with the bypass open they put almost no load on the engine, I’ve seen numbers showing that with the bypass open but the engine still driving the blower eatons cost something in the range of .3mpg (properly tuned with actual boost you could potentially see an MPG increase depending on your right foot)
Re: if u were to supercharge a v6 which one would u use
ill ahve to look into it a bit more then i quess, any recomendations on which size eaton i should be looking at for a 3.3L motor ???
the more i think about it the v6 has a nice lower manifold that with some fab work cant have an eaton mounted directly onto
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
ive actually been thinking about it, im just gonna keep the new motor turbocharged, except im not gonna install twin turbos like i had originally wanted to.instead im selling of the turbos i do have and am going to be running one very large single
maybe in time ill go with an m90, but im gonna have to fab up just as much stuff to use it as i would to do the twin turbos.thats why i just decided to stick with a single turbo.all the stuff im selling will cover the cost of the gt66 and then some.and is gonna be the simplest route to go right now.
actually the hardest thing im gonna have to do is fit the 4 inch downpipe in the car.but ill prolly use a 4-3.5 or 4-3.0 reducer right off the housing to bring the dp size back down to a more managable size
If you figure out how to sneak a 4” pipe past the V6 tell me, maybe it will give me some ideas, I’ve been trying to figure out the same for a V8, and I’m seriously considering cutting away part of the subframe and possibly the firewall.
Car: 1984 Camaro z28
Engine: 350 TPI Twin T70 turbos
Transmission: th400
Axle/Gears: stock putting in a 9" with 3.89
use a 3.8 motor with a series 2 supercharger on it rebuild the motor to hold more boost...get a 3.23 gear on it and have a fun time my friend put it in his feiro and he ran 12.57
toronto formula
11-10-2015 06:17 AM
