audi volvo turbo mfg.ers?
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
to day i headed to the junkyard and found 4 turbos 2 in audis and 2 in volvos both identical but my problem is they seem very small like 5-6 wide 9-10 long
they where made by ^
/ K \
/ K K \
well that is what is cast next to the spec plate on the compressor side
but the tags are in german with german abbreviations so i cant tell what they are or if they would be usefull for a twin 350
/ K \
/ K K \
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
It all depends on what Audi. If it was a 5cyl Audi, it was weither a K24 or K26, there should be a little blue tag on the outlet of the compressor housing, it will tell you what it is. FWIW, the K26, feeds a 2.2L motor, to about 7k, and will put out 16psi-20psi. they really run out of steam above that.
Here is a link to the compressor maps.
http://not2fast.wryday.com/turbo/maps/k26_map.jpg
http://not2fast.wryday.com/turbo/maps/k24-70gga.jpg
--John
who is currently working on this....
--John
Those are Borg Warner KKK Turbos for the Audi. They are WAAAAYYYY too small for just about anything. A twin 350 would be spooled at idle and out of steam around 4000. They are not reliable turbos which are known to snap the shafts.
I always thought the Volvos used a Garrett T3 based turbo. Then again, I havent looked under the hood of one in awhile. I have 2 T3 60-trims out of 2 Nissan 300zx's single turbos which would work alot better than those turbos you found. $300 shipped.
New2Chevy
09-28-2015 12:35 AM
