3.1 Turbo intake
3.1 Turbo intake
Would an old 3.1 turbo intake be an upgrade over the mpfi on an iron head turbo 3.4 or could it be used with the alum. heads .You can see I don't know much about interch. between fwd and rwd.
im assuming u ar talkinmg about a 3100 manifold.no it will not work on a rwd engine using the iron heads.it will work if u swap over the the gen 2 aluminum heads,except u would be better off going right to a gen 3 topend 3100/3400 sfi stuff
Hotrodboba400
12-10-2019 07:07 PM
New2Chevy
09-28-2015 12:35 AM
