Twin Turbo 305
Car: 1986 Chevrolet Camaro Z28/99 Aurora
Engine: LB9 5.0 TPI/4.0 V8
Transmission: 700r4/?
Axle/Gears: 2.73/3.08
Twin Turbo 305
Does anyone know what I would need to put a twin turbo system on my 305 tpi? What parts will I need and if anyone has done it what kind of numbers are you making?
Not to much thats why I asked. I couldnt find a how to thread in the power adders section that said specifically Twin turbo 305. The only real experience I have with turbos are on my 95 silverado with 6.5 turbo diesel. I could use some guidance on this.
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
The concepts are the sale as your '95 Silverado, just different packaging. 305 has the same outer dimensions as 350, 383, 400, 406, 434, etc...
An old page, when I first built the Z28tt, might get you started (along with reading all the stickies in this forum): http://www.skulte.com/turbo.html
Car: 1987 Z28 Convertible
Transmission: 5-speed
Progressive methanol injection system by Alkycontrol. The plastic reservoir you see is the container for it, not a radiator overflow bottle. The pump is located just below the MSD box and the controller is in the cabin. I also have twin air-to-air intercoolers that are mounted low that cannot be seen.
Willie
Willie
Car: 1989 iroc Z Hardtop
Engine: 350 tpi
Willie
Willie
Street Lethal
04-30-2019 12:14 PM
bjpotter
01-22-2019 12:27 PM
