Don't sell your 350 car, 305 sucks!
#51
Re: Don't sell your 350 car, 305 sucks!
3.736”
A larger bore allows for a larger unshrouded valve area which helps breathing.
OTOH, it also makes for a larger, more spread out chamber which results in a slower, less efficient burn that is more prone to detonation issues…
#52
1 Post
Car: Modified 1985 Z28
Engine: 355 Carbureted
Transmission: TH350 Turbo
305? 350? Screw em Both. Give that to your grandma and find yourself a chevy 400 ci . If you're modding out an engine for hp and torque, might as well make your money really worth it.
Here ya go, you can start with one of these:
http://cgi.ebay.com/ebaymotors/Small...11294542QQrdZ1
http://cgi.ebay.com/ebaymotors/Chevr...00942085QQrdZ1
http://www.customdesignperformance.c...vyengines.html
http://www.comeracing.com/weblog/2006/06/08.html
Bitchin!!
Bitchin!!
#54
Car: 1992 Formula
Transmission: auto stock
Axle/Gears: 3:42
I finally went this past weekend and had a 3:42 gear put in, WOW, what a difference! The gear and kit was 300.00 and parts and gear oil was on 280.00.also had a part to be replaced that was 160.00 ( forgot the part ).
Now I plan on getting headers ( car is a '91 305 ) and 3" exhaust to compliment that. Thanks to all posts!
Andy
Andy
#55
Guest
Posts: n/a
Other way around. LS1/LS6 are closer to 4" than 3.736". But GM is moving away from that anyway, the LS2, LS3, LS7, and probably LS9 are all 4" or more.
#56
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
to everybody arguing over moters.....305=P.O.S 327....decent moter, but by the time u reached your optimium rpm range(which is very high) the 350 has done hit its "happy place" caught another gear and is half way down the track......the only thing a 327 is good for is a "correct" resoration on a vette.......plus......have u ever seen a 4 bolt main 327 or 400 sb? no.....A 350 is the moter to tune in on because the parts are available...and if u sling a rod.....so what go to the junk yard and pick up a new block...327, 400.....things aint that simple...my point 350's are available....( oh yeah, and the 400....while it may be able to smoke the 350 with similar mods, well...i just hope u aint doin 2 races back to back.....cause u gonna run hot as hell...)
#57
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
I don't know why 305ci gets a bad rep. My stock 305 with over 135K miles is putting out about 310 FWHP right now. The plan is to turn up the compressors and make a peak 400-425 FWHP at 5000 RPM. The 305 engines (not "moters") seem OK to me.
#58
Car: 2000 BMW M5
3.7 bore, see 1st page. I had an extra set of world products sportsman heads kicking around, but realized I'd have to notch a 305 I have in one of my cars just to use them. LOL.
#59
#60
Car: 2000 BMW M5
FWHP? What front wheel driver, do you have a 305 in?
#61
Car: 87 GTA
Yes, I'm for real...
RWHP=Rear wheel Horse Power
FWHP=Front Wheel Horse Power
For all I knew, you were referring to an older Olds Toronado, that has a tranverse V8, and FWD.
#62
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
There is no reason a small bore motor can't make decent power. You do not need a 2.02 valve in the smaller cylinder. Y0ou can run a 2.00 valve on a conservative cam.
As for the larger motors outrunning it I should hope so. But think of this. How many 10 second cars do any of the naysayers here own or have seen?
The 305 can produce more than enough power to surprise 9 out of every 10 cars it lines up against.
I'd like to here that crybaby argument after getting your **** handed to you by a 305.
Try telling the guy he shoulda went a with a 350 instead of that 305! What will be your reasoning? He woulda laid an even bigger beatdown on you!
If I ever sell the TTA I'd love to build a 305 motor.
Splay/stud the mains(already have em), Vortec heads Max port(no reason to machine the pockets I'd use a smallish cam), I'd use the TPI with a vortec base and at least a T-66 turbo. If the heads turn out that good it may be able to use a T-70. All but the most hearty of cars on this board wont be able to hang with it.
Who wants to donate a 305 Tpi car to me for the test..... I have the hotside parts, splayed caps, studs, fuel pump, DFI, etc......
#63
Originally Posted by junkcltr
I don't know why 305ci gets a bad rep....
#64
As much as I’m all for going fast with a 305, Smitty’s car is not a good example, since it’s only a 305 WRT to displacement, not wrt to the 305’s limitations, that thing has a 4” bore, and he’s not so much going fast with a 305, but going fast with an overbored 302 or destroked 350 (355…).
#65
Car: 1985 iroc
Engine: 305 H.O.
Transmission: 5speed
Axle/Gears: 3:73
everybody talks all this crap about 305s.. really nothing wrong with them.. if you have the older cheaper lg4 motors then yes they are just about worthless.. l69 are the best.. flat top pistons, put a cam intake and carb on them along with some 3:73 and it will leave most 350s behing along with almost any 4.6 mustang.. they are a very rev happy motor, mine pushes 6500rpm on stock internal and i have never pulled the heads off.. still factory sealed.. its also all in the driver..
#66
Car: 1989 TTA #1240
Transmission: 2004r
The car still ran low 11's on a stock block 305 with the supercharger. Even that car woulda spanked most of the clowns on any board bashing the 305.
It's a preference.
With the wide spread use of turbochargers now any engine can make gobs of power. When you to the track now a days you see all types of cars putting down disgusting numbers they normally couldn't do....
Last time out I saw a BMW, a few Fox Bodied Stangs and the normal cars like Evo's, STI's, older Toyota's etc. That argument on displacement should only be compared factory equipped or for n/a comparisons.........
It's a preference.
#67
305 TPI cars arent bad but they really need a cam/head work then abit of intake work to compete.
there are several guys on this board now with 12 second cammed/headed 305's. some with carbs, some with fuel injection. Granted it only took my L98 with bolt ons to get a 12.9 pass and if i add a cam to the stock longblock, i'll be deep 12's more than likely.
BUT a hotcam and a HSR with proper gear will SCREAM on the topend in a 305. may not make alot of bottom end but damn it be like a 302 DZ engine for sure.
If you dont want to spend the money on all that work, ie heads/cam/intake bolt ons, etc, then just get a procharger and be done with it. should make near 200whp stock and then jump to 350whp or more with the blower
#68
1 Post
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
You realize you can build a decent 350 small block for around 1K right? Why dump tons of money into that 305 when you can just create a cheap, more powerful 350 and then add whatever power adder you want. You will spend a lot less money making a 350 faster then a 305.
#70
1 Post
Engine: 3.8
Axle/Gears: Dana 60
A mild head and cam package can get your 300-350 easy (including exhaust work). Talk to your local performance shop and ask them what they have been using. That way you know it is proven and they know how to tune for it.
#71
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
i regularly smoke stock l98 cars
on the street that is
#72
1 Post
Engine: 3.8
Axle/Gears: Dana 60
with your modified LB9? Good work. I think you are missing the point...
#73
Car: 1989 T/A
im not missing the point. i know same $ into a 350 will give u more hp than the same $ in a 305. most of my mods are bolt on's so if the old lb9 ever pops it will all go to a nice stroker.. 305's are still great street machines if done right. and i surprise the hell out of most people.. when i say its just a 305. especially the 4th gen guys. i will be adding a crane 2032 and a prochager over the next few months.. and yes it will be fun!
#74
1 Post
Engine: 3xx ci tubo
#75
Car: 1989 T/A
i really dont like to lie to people.. thats pretty stupid. saying u have a 305 when u have a 350 is just dumb. ill stick with my plans.
#76
1 Post
Engine: 3xx ci tubo
Exactly, bragging about a 305ci is the same. People aren't trying to shoot down your 305ci plans. They are just trying to let you know that the engine config. is not cost effective when compared to other blocks. I have a 305ci with boost and when it croaks a 350ci will probably replace it.
#77
Car: 1989 T/A
tell me about youre boosted 305,, specs hp. tq what kind of sc..
#78
1 Post
Engine: 3xx ci tubo
All the info for it is here:
https://www.thirdgen.org/forums/powe...turbo-tpi.html
It is slow, but fun.
#80
1 Post
Engine: 3.8
Axle/Gears: Dana 60
One thing I learned thru all the years, don't **** around with **** that you know your going to replace later down the road. It is just a waste of money and time. If I could go back in time and tell myself "Don't modify that 305, it's a waste, this is why..." then I would. There is just a lot better out there for a lot cheaper and more cost effective in the long run and I could have saved so much money and time if I would have just started with my current motor I have now, then trying to make my 305 fast before. That whole "Well I like it because its a 305 and I shock people" is a lame excuse. The only people you are shocking are 13-14 second cars. When it comes down to it, it isn't fast and you will want to go faster in the future, which will involve you replacing that motor with something bigger or better, so why dump money into it?
That is just my 2 cents.
*This rule doesn't go towards the things that can be swapped onto a different motor. ie: nitrous, headers, etc...
#81
Car: 1989 T/A
dude, tahts exactlly what i said.. its a bolt up car.. everything could be swapped to a diff motor.. most of my mods are suspension/exhaust and such.. and the sc will also go to a bigger motor.. but this is a street car. not a track car. i dosent matter to me if i run a 12.7 with a blown 305 or a 12.2 with a 350.. its a street machine. and a dahm nice one to add. and i dont do ANYTHING to impress anybody!! everything i do is to satisfy myself. and what i want. not to mention there's a ton of 305's on these boards running 13's and 12's which to me, is a fast street car.
#82
1 Post
Engine: 3.8
Axle/Gears: Dana 60
All I am saying is if your going to do it, do it right and not waste your time. But to each their own. I just couldn't stand myself if I had a supercharged V8 that ran 12's or 13's. That would **** me off.
#84
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Bottom line is if you are looking for power and speed you want to avoid a 305. Stock a 305 is junk, but you can make anything fast with money. It really is not cost efficient to use a 305. They are good for a ton of nitrous or forced induction due to keeping cool easy, but as usual the more cubes would make more HP.
I have had 2.8 V6-455 pontiac, and as usual i will olmost allways pick more cubes.
jay_d -Yes they made a 400 small block with 4 bolt mains, but it is even said the 2 bolt is stronger.
#86
Car: 1989 T/A
ok,, im sick of arguing with children about what motor is better.. duh. common sense more cubes = more power.. we all know this. but why do u children insist on ragging on the motors that the majority of our cars came with from the factory?? modding one and running fast is a good thing. and when it dies, u go bigger and better. if u dont like a stock thirdgen powertrain. then dont comment on them. if u can help people on this forum with some good info, then give it. or go surf the web. im just sick of hearing 350's r faster drrrrrrrrrrrr,, $%&(++_!@# no f-in sh++,, but so is a 400, 396, 454, 383, 502 and so on... and one last word. i will be glad to run anybody thats runs there mouth on how 305's suck, if they have a stock or mild 350. any offers????? grow up already people! just answer peoples questions. not " u duh get a 350? duh"
#87
Guest
Posts: n/a
13.8@104 with a 2.3 60' time and 7-8psi, only time I ever took it to the track. With a decent 60 (I was on old worn out street tires) you can go ahead and figure out what it would have ran. I'm now running twice that psi and havent had much trouble with anything I've come across on the road although quite a few have tried. Hey its a thirdgen, its supposed to be slow.
Only thing thats done other than the Vortech is some SLP headers and a catback. I got the s/c used so... not much invested and it was a fairly simple bolt on. Would a 350 run faster? Probably. But I dont have one, and the 305 is fine so far so... no reason to change it unless I feel like it. I was not trying to build the fastest car, just playing around with what I've got and its been fun.
#88
1 Post
Engine: 3.8
Axle/Gears: Dana 60
#90
1 Post
Engine: 3.8
Axle/Gears: Dana 60
That is true but there is a point where technology starts to compenstate for cubes. Not that GN's or TTA's are very high tech, I meant for the other applicants.
#93
Car: 1989 T/A
dude, u must have contradicted youreself about 3 times already.. i think most of us know about tta's and gn's now youre saying forget cubes when u have boost. before u were saying get 45 more cubes.. dude just stop already! youre remarks are BS u sound like hillary clinton at a debate full of s+++! enjoy youre boosted v6 and ill enjoy my supercharged lb9. but youre still a jack==== for puting down anyones motor here on this forum. .. i just had an idea, wouldnt youre car be faster with a 400 block rather than that 3.8??????????????
#94
Car: 1989 T/A
hey 91bird,, you know, if u added moore boost youre car would go faster? hey if u added more cubes youre car would be faster? if u added both youre car would be faster? hey if u twin turbocharged a big block and added a 300 shot of juice yure car would be really fast? just stop stating the obvious.
#95
1 Post
Engine: 3.8
Axle/Gears: Dana 60
But 400's like to crack sometimes at the mains so I probably wouldn't go with a 400.
youre remarks are BS u sound like hillary clinton at a debate full of s+++! but youre still a jack==== for puting down anyones motor here on this forum
And I am not putting it down, the question was asked, should I modify my 305? I simply anwsered with "no, your money will go a lot furthur with a different motor." It's a fact. I have been on both sides and I just don't find any sense of dumping time and money into a motor that barely produces and competes with real street cars.
#96
1 Post
Engine: 3.8
Axle/Gears: Dana 60
#98
1 Post
Engine: 3.8
Axle/Gears: Dana 60
Ah. What tires did you go with? I am a big fan of the M/T drag radials so far.
#99
<edited - Let's keep the BS level down - This board is "power adders", not insults. If you're not adding any tech to the discussion, please don't bother posting.>
