Powershot plate vrs cheater plate
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
I am converting my super powershot plate kit to a cheater kit and am wondering. Does the powershot plate flow enough to support the cheater system or do you need to get the cheater plate?
Engine: 584
I have been using the powershot with all the different setting and getting pretty good with tuning it. I just want to be able to have it adjust up to 250. I don't need anymore then that. Right now the powershot kit will go to 175.
Car: 91 z28
Engine: 383 sbc, 88mm turbo a2w IC, CSU 750
Transmission: th-400 PTC 4000 stall
Axle/Gears: ford 9" 3.55 gear
the plates themselve i believe are the same part, its just the solenoids that differ, the cheaters obviously can flow more
monte87cortez
09-26-2015 08:10 PM
