Horsepower #'s for Twin Turbo 383?
Car: '85 Camaro
well i should be putting my 383engine in my car in a couple weeks and a have the twin turbo's installed. I was curious how much horsepower i will be able to crank out. Here is the list of stuff:
383 block, completely studded all around
Forged Dish Top Pistons w/ 8.0:1 CR
Forged Eagle Rods
Forged Eagle Crank
Comp Cams custom Roller Turbo cam XT262H (.580" lift)
Crank 1.6 Roller Rockers
AFR Eliminator 195cc heads with 75cc
Victor JR. Polished Intake
Demon 850cfm blow through carb
(2) GTS Turbos w/ Comp. housing A/R.60 Turbine A/R.63
Internal Wastegates at 14 PSI
1200CFM FMIC
Full MSD Ignition with Timing/Retard
100 Octane
This is going to be my weekend warrior and would like to get AT LEAST 600HP at the crank. Oh yeah, i also have NOS setup on it also with purge which would probably be just for show
Just curious if anyone has a similar setup and what numbers they making. thanks for any info
Forged Eagle Rods
Forged Eagle Crank
1200CFM FMIC
100 Octane
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
good god, i want your setup.. trust me, you will make your 600hp.. 600rwhp that is..
Car: '85 Camaro
well i dont have pics of the engine all together yet. It's still in the shop getting built. I do have some pics of the parts that are being put on it. I'll try to get some pics posted later today
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It is hard to say without knowing the size of those GTS turbos. Are they T3 or T4 size? If they are T3 then you are going to be spinning them hard to get to 750HP. T4s would be good though. I don't see how anyone guessed at HP without a compressor map and T-series size. It sounds like a well built engine that can withstand some HP.
EDIT: The comp. housing A/R doesn't mean much. Do you know what size the comp. inducer wheel is and what the trim size is?
Car: '85 Camaro
Well im still kinda new to turbos so im trying to get that information for you. I know they are T3/T4 turbos and here are some specs that i have of them:
.50 A/R COLD
.63 3" SUPER VBAND OUTLET
3" INLET DIAMETER
2" OUTLET
.57 COMPRESSOR WHEEL TRIM
.60 A/R COMPRESSOR
.63 A/R TURBINE
57 TRIM
.50 A/R COLD
3" INLET DIAMETER
2" OUTLET
.60 A/R COMPRESSOR
.63 A/R TURBINE
57 TRIM
.50A/R cold & .63A/R compressor? the cold side is the compressor...
any link to 'em? ebay turbos?
I have a pair of "big shaft" T70's with .70A/R comp. .84A/R turb.
Car: '85 Camaro
sorry i dont have any link to the turbos, and no they are not ebay turbos. My brother had them brand new and was going to use them on his car but sold it so he gave me them to use. my bad about the compressor mix up. again im still new about the turbos.
Car: '85 Camaro
Car: '85 Camaro
my brother bought the manifolds from a friend over in Sacramento who does custom fabrication. We then had them sent out to get chrome plated. I believe it cost around $350-$400 to have it all done. The flanges and tubing are thick to avoid any warping
Car: 84camaroz28
Engine: 97vortec 350 twin turboed
Transmission: transbraked turbo350
Axle/Gears: 73 chevelle12bolt 366gears
how much boost you going to run that will matter to.
1 Post
Engine: 3xx ci tubo
The engine is built for revs. The compressors look like T4 so I am guessing 57 trim from the specs you posted. The turbines look like T3 and .63 A/R from the data you listed. I am guessing you are going to use good mufflers like Hooker's or Dynomax with single 4" or dual 3" exhaust. A good cool air intake.
With the headers, intake, heads, cam (good cam choice), and FMIC it is going to be quick.
I guess around 800 FWHP at 14 PSI of boost. That is a good combo of parts there. The only thing I might think of changing later on is going to T4 turbines. That thing should spool quick and make very good HP. You picked good parts.
Car: 55' Chevy, 57' Plymouth, 67' Camaro
Engine: TT406, NA440, 230-6
Transmission: TH400, 727, ST10
Axle/Gears: 9" - 2.75 gear, 8.8" - 3.27, 10bolt
The T3 turbine is going to be the choke point on that setup. Its small for big HP numbers. I would say you should see 650-700crank HP without too much problems though. Should be a good street setup and not have much lag.
Bigger turbos like a pair of T66's would be a better setup and would easily make 1000hp with your combo. I have a 400 cube mopar with a pair of T66's and it hit 1200hp. I should have used T70's.
Car: '85 Camaro
yeah these turbos aren't the biggest out there but its something for now. If its around 700HP that would be great with me. I would build the suspension, structure, and maybe tranny up first before i upgrade to bigger turbos.
What trans are you using?
I don't think there is an automatic overdrive that will stand up to the torque of a TT small block. I would go with a TH400 for reliability, and a mild gear in the back, like a 3.23. a 700hp turbo motor will have a TON of torque and a mild shift point. Most turbo setups like a mild gear because they have so much torque.
Car: '85 Camaro
Right now i have a built 700r4 with a 3500 stall and 3.73 gears. The tranny shifts strong right now and had no problems with my last 383 which had 475HP/525TQ. I would like get a beefed up TH400 and a transbrake, but i like the overdrive the 700r4 has
The input shaft is weak on TH700's with biig power, plus the OD unit is not that strong. If you have no traction is will last for a bit, but as soon as you start getting it to hook...
What rearend do you have? Nothing stock will survive that...
Car: '85 Camaro
Lol, scary enough it is the stock rear end 10 bolt. All i done was upgraded the 28 spline axles and got the Zexel Torsen diff. and the rear end girdle. That is why i havent snapped anything is because i get no traction at all. I will take it easy once i get the engine in and work on the suspension and rear end. I most likely would get it backed by a TH400, HD driveline, and either a Moser 12 bolt or the bolt in Ford 9"
