P1SC Question
Car: 1983 Camaro Z28
Engine: 584
Transmission: TSI Glide
Axle/Gears: Quick performance 9 inch
P1SC Question
I have a quick question for you guys that are running a procharger kit......... Acually it may be a couple of questions..... I am looking at buying all the components for a procharger P1SC kit along with some form of an intercooler. My problem is that I have 10.76 compression. If I was to strictly run on 110 race gas and keep boost low would I be ok or would it not make very much power or damage something? I have a forged bottom end with trickflow heads right now........ Just curious what everyone thinks.
Also I am curious if I can use the stock lines running up to the engine and connect a electric pump to the line or will that not flow enough and I have to change lines from the tank as well?
Could anyone send me a copy of their procharger directions please? Thanks for any help in advance. Been runnin nitrous but would like to change to something else.
Engine: 584
Are you running one of those kits?
Is anyone else running high compression and boost as well on here?
Engine: 584
moderate boost being only 6 psi? or more? maybe with the 110 I will be able to squeak by with boosting like 8 or so......
