100 shot on the iroc
Old 10-15-2006 | 11:19 AM
roachjuice's Avatar
Car: 86 Omni GLHT
Engine: 2.2 Turbo/Intercooled
Transmission: 5 speed
Axle/Gears: 3:85
well i went to the track last night with the new cam and all the bugs out of it..... it went a 15.4 @ 90mph..... i gained 2 mph.... still stock stall.... well this guy has a NOS kit for tpis and he wants 150 bucks for it.... i'm thinking of doing it... my ? is am i safe with a 100 shot???? my problem is is that i bog off the line.... i need a stall but i think im going to spray it..... what do ya think i'll run???
Old 10-15-2006 | 08:05 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
You'll be fine.
If you have nitrous, you won't bog off the line, you'll spin.
Watch the timing, fuel pressure and get a rev limiter.
Old 02-13-2007 | 08:54 PM
5literTPIterror's Avatar
Car: 91 camaro rs
Engine: 355, blowthru, 78mm turbo
Transmission: th350, art carr converter
Axle/Gears: stock 7.5, 3.23s, minispool
should be fine.
i have a 89 formula 305 tpi,T-5, and ran 15.1 @91 N/A...
put ET Streets on it with a wet kit, single nozzle after the MAF, sprayed a 150 shot w/ only 650psi bottle pressure and ran 12.93@108.17 w/ a 2.0xx 60'
this was through dual cats, and manifolds, now i have 1 5/8" shorties no cats and 3" exhaust, and a bottle warmer.... im gonna try to get down to 12.5 before the 305 dies.
good luck
CarGuyDennis
137
12-06-2016 11:02 PM
1992rs/ss
16
01-28-2016 09:58 PM
mustangman65_79
08-11-2015 03:17 PM
Fronzizzle
08-09-2015 01:15 PM
Quick Reply: 100 shot on the iroc
