nitrous pressure
Old 10-07-2006 | 11:26 PM
graphicideas1's Avatar
nitrous pressure
at what pressure should a 10lb bottle be refilled? i am sure you dont wait to zero
Old 10-08-2006 | 05:07 AM
1991CamaroRslow's Avatar
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
You can have low bottle pressure on a full bottle, or high bottle pressure on a low bottle. I usually get pulsations when the bottle gets close to 2 pounds no matter how warm I have it so I've made it a point to leave that last 2 pounds in and save money on my refills. You want to see between 900 - 1100psi on the bottle with 1000 being pretty close to optimal. When the pressure starts to dip to around 600 on a bottle that's around 80 degrees you know it's getting to low for any real use and you're just wasting that last bit of nitrous. You should consume 4 pounds of nitrous for every 1 minute of use for every 100hp. This is a good rule of thumb to go by so you know about how much you're using and when it's getting time for a refill.
Old 10-08-2006 | 10:13 AM
thanks
Stryker412
09-20-2015 07:59 PM
anesthes
09-18-2015 01:34 PM
NastyEngines
Group Purchases
09-08-2015 11:14 AM
TBRays98
09-06-2015 06:05 PM
Quick Reply: nitrous pressure
