Rebuilding a Pro-charger
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
anyone here ever rebuild a pro-charger...seals and baerings that sort of thing?
im sure its not all that complicated, the problem is getting the part no's from ATI or any torque specs.....they're f**** c*** monsters down there.
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Yes, I rebuilt my P600B because it was leaking a slight amount of oil past the oil seal. ATI will not give you any information or sell you any parts whatsoever, so you will need to do some research on what parts will work since you can't get their proprietary stuff. ATI wouldn't even give me a quote to inspect my unit, they just wanted me to send it in.
The high speed bearings are ~$75 ABEC 7 angular contact thrust bearings with a phenolic cage (the impeller moves upwards of 50,000rpm), the low speed bearings are regular ball bearings with a metal cage. You will need to do some measuring to figure out what oil seal you need but Napa came through for me with one from Chicago Rawhide. The impeller is pressed onto the main shaft. The impeller nut requires a special tool to remove, you might need to get creative. Take pictures as you take it apart and put fasteners into marked baggies so you know what goes where.
The cool thing is, since everything is press fit/interference fit..everything is machined with stops. So you press the bearing on until it's all the way on. And you press the impeller on until it's all the way on. Etc. The bearings are held in place with clips, and if those clips don't line up with the grooves in the housing, then you know something is wrong.. really easy actually.
If your Procharger explodes after I gave you some sort of false hope that you could rebuild it yourself, I take no responsibility for what I have just posted.
high speed bearings aren't cheap no matter where you get them from.....i'd be willing to bet its either a timken or a BCA bearing # though
Axle/Gears: 3.73:1
That's what I did, I went to a place here called Johnson Bearing with my numbers and dimensions... they are a wholesaler that specializes in nothing but bearings. They were still pretty expensive (well, I consider $75 a bearing expensive, anyway).
Car: 87 Formula
Engine: L98-350
Transmission: 700-R4
Axle/Gears: 3:08 Posi (Disk)
procharger didnt charge us for looking at out p600b. they had it for 5 days an called us with the cost to rebuild it and it came back looking new.they've always anwsered our questions when we called long as we gave them the ser# number....Sam
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
It seems that the SC shops are a lot like the turbo diesel shops, Harley shops, etc. They are tight-lipped and try to get everyone thinking that it is rocket science and only a select few can get the parts and do the actual work when in fact it is just cheap stuff that mostly anyone could do. I bet most of the hard parts are just from some generic turbo.
Axle/Gears: 3.73:1
The impeller and compressor housings definitely aren't turbo pieces. They have a gear drive inside of them, 4 bearings and two shafts which obviously turbos don't have. I'm guessing about the only things that aren't proprietary ATI pieces are the bearings themselves... whether or not the other stuff is all made in-house, I don't know.
Car: 86 Z28
I just disassembled my p600b Procharger with 160k miles on it. It started to ruin belts rather quickly. I have found replacement bearings and one seal. The high speed seal seems to be made of solid Teflon and I have not found any type of seal like it.
I have enjoyed this supercharger very much and have found it to be very reliable.
Thanks,
Steve
Thanks,
Steve
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Alot of info at SuperCharger Help - Powered by vBulletin
3.8TransAM
09-27-2015 08:37 PM
