nos tpi plate kit
Car: 1991 B4C, 1992 RS
Engine: 355, 305
Transmission: 700r4, 700r4
Axle/Gears: 3.73, ?
nos tpi plate kit
I was wondering what is the largest shot i could run with the nos tpi kit (nos-05151 i think it is?). It comes with jets for a 150 shot but could i go larger or would i need bigger solenoids? also does anyone know of a site with a chart to tell u jets to h.p. thanks!
Engine: 355, 305
Axle/Gears: 3.73, ?
awesome thanks, anyone else know what kinda shot i can run through my kit?
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
You can probably squeeze a 200 shot out of it but it won't be optimal, the plate will flow alot; the solenoids won't flow all that much. Upgrade to the larger solenoids and you should be set.
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
There is a guy on corvette forum who has run a 250 shot through that plate with the bigger solenoids and -4 line from the solenoids to the plate.
1992 Trans Am
05-10-2023 07:19 PM
mhatfield 14
10-24-2015 07:48 AM
Sanjay
08-12-2015 03:41 PM
