Blower from a movie question
Hi all,
I saw in an 80's movie a GTO that had big ol' blower on it that the driver could engage and disengage while driving. Is this a real option or just a Hollywood effect? Cause I've never seen anything like it in Summit or Jegs
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Ahhh, Madmax did that also.
It has to be possible. they did it in the movie didnt they![](https://www.thirdgen.org/messgboard/wink.gif)
*1989 RS
*Red, Daytona Turbo fiberglass hood, chrome 16x8 IROC wheels
*355 CID
*TPI ported plenum, SLP siamesed runners, Edelbrock high flow intake
*SLP 1 and 3/4 headers with 3 inch catback
*Richmond 3.73, Auburn Posi
*Modded 700-R4, 2800 stall converter
*eibach pro kit and hotchkis sturt tower brace
"There is no way you have a 350 in that car. They are made to have 305's and a 350 wouldnt fit"
-local parts store genius-
*1989 RS
*355 CID
The problem with this is (roots style) that once the blower disengages, the vanes basically shut off air flow to the engine.
Now a centrifugal blower could be disengaged and allow the engine to still suck air. An A/C clutch system might work, but the factory clutch is rated for something like 5 hp. It takes 50+ hp to turn superchargers.
I stand corrected. Good tip about breaking in the engine, the "disconnect the blower part".
I have a 383 with a ATI going in a boat. I'll first break in the engine and then add the belt.
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
I saw a car in motortrend that used an electromagnet to engage and disengage a centripical style supercharger.
Andrew
Andrew
