N2O and stock pump
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
N2O and stock pump
I am wanting to do a nitrous set-up,but want to make sure that the stock electric pump I have will be sufficient enough. I pulled out the old TBI 305 and dropped in a carbed 350,but left in the electric pump and added a Mallory regulator putting about 6-6.25 lbs of pressure to my carb. At WOT the pressure stays about the same,fluctuating at the most of maybe 1/4 lb. Will this be good enough for around 100-125 shot with nothing to worry about? Also,isn't there a safety switch in case my pressure drops below a certain level? I want to take every precaution possible,as this is a NEW,un-rebuilt motor with only about 1200 miles on it.My wife says I spent too much(to her anyway) just for a motor,so she'd kick my @$$ if I walked back home and handed her a piece of my piston skirt from a blown motor.So I'd appreciate any and all comments.Thanx guys.
'91 RS, 375hp 350
New paint-solid black
ROH Snyper wheels-17x9 wrapped in 275/40/17
ASCD SS hood, High-rise Z-28 spoiler,shaved handles/antenna,
Hooker super comp 1 3/4" headers,dual 3" exhaust,two 1-chamber Flomasters,machined hi-perf GM heads,Holley double pumper 650 w/50cc pumps,Power Plus 360* high rise aluminum intake,Edelbrock Elite valve covers/14x4" open air cleaner,Mallory AFPR,Proform HI-perf HEI disributer with curve kit,Crane 292 cam,2500 stall converter,Eibach Sportline springs,KYB struts/shocks,completely rebuilt steering linkage,36/24mm sway bars,12.7 steering box,wonderbar,145 gauge cluster,Auto meter gauges,dual guage A-pillar pods,180* thermostat,dual push/pull cooling fans.
75-125 shot NOS system planned.
President-Austin 3rd Gen F-body c.c. - message board at
www.hpsmotorsports.net
See my car and others at www.ride4life.net
[This message has been edited by RSpeed (edited November 27, 2001).]
'91 RS, 375hp 350
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
As long as your pump keeps a miniumm of 5psi through out the RPM range it will be fine. NOS makes a fuel pressure safety switch and it is a very good investment in my opion. It's part number is NOS-15750 and cost only about $36. Cheap insurance.
[This message has been edited by Superman (edited November 27, 2001).]
theshackle
03-05-2017 06:37 PM
toronto formula
11-10-2015 06:17 AM
