383 Supercharged
383 Supercharged
I'll be starting my 383 buildup as soon as I can, but I had a question about supercharging. It will be a TPI motor (miniram). What supercharger would be the best for it, how much maintenance are they, what kind of chip would I need(if I do this I don't want to have 2 chips burned just because I decided not to supercharge it while building it), how much power would we be looking? Any numbers and tips would be great. Thanks
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
Naturally aspirated take a second off my time. (See Sig) Keep in mind I have a mild set-up for driveability and emissons.
'91 Formula
383CI Superram, Sportman II's
SLP Cam 214/224 .470/.490
Vortech V1 S-Trim
5-speed
3.42
12.34@117.04, 1.91 60Ft.
on Drag Radials
'91 Formula
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
Hey 91 Formula,I noticed in your sig that you have almost the same setup I want(whole car
not just engine). Would you mind telling how you made it possible, I'm trying
to do it for less than an arm and a leg, I'm only 18 and I just started
working again. But looking at your times I may not want a supercharger. I
don't want to have to put in a rollcage. I think 13's would be fine. Thanks
for your help.
for your help.
I had the short block built for $5000 incuding parts. Parts are:
1) 350 block
2) All Machineing
3) 4 bolt mains with splayed billit caps.
4) Scat 1pc rear main seal 3.75" stroke crank(nodular iron) $250.00
5) Wiesco forged pistons
6) Eagle H beam rods
Heads I got out of Summit racing. I did every thing else.
'91 Formula
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
1) 350 block
2) All Machineing
'91 Formula
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
Hey '91 formula. Please take a look at my reacent post. I have a setup just like yours,.....however..........
The post is "11 second Vortech,...w/in"
SUPERCHARGED 87 GTA: Blk/Gld w/Superam, 355cid Trickflows, forged pistons 9.5:1. Auto 2,600 stall, 3.45 9 bolt disc, Best ET (Nat. Asp.): 13.567 @ 101.900 w/ a poor 60ft. Best mph: 104.3 -*100% NYS emissions legal*
http:// www.community.webtv.net/munks87/JustinsGTApage.com
VORTECH S-TRIM completed 7/9/01: 10 & 15 LB. Pulleys, HKS race bypass, serpentine swap. No ET: 8/26/01, Blew motor before track. Rebuild in progess. Beat a freinds 12.9 @ 108 Camaro by A LOT. EST. mid-low 12's as it was. Looking for 11's w/ new motor.
Yeah, If I had an automatic., I'd be in the mid 11's.
'91 Formula
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
'91 Formula
Vortech V1 S-Trim
5-speed
3.42
on Drag Radials
LT1Formula
10-08-2015 08:34 PM
