procharger?novi2000?3.8turbo?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
if you look in my sig there's my mods a hella lot of work and am tired of n/a cars(it's really starting to get there now but if my heart isn't in it why bother).the question i have is i know it's stupid to start over and i'm really considering just switching to a g body(gn)haven't made up my mind yet!but if i was gonna do a new project what would be recommended a novi2000 or a procharger(both intercooled on a 3rd gen iroc),keep in mind it will be a mild 350 under lots of boost,a 700 with a vigillante converter and a 3.45 9bolt,or would the 3.8 turbo be a better option,the gn's look mean but the interior looks like a grand pappy mobile and they handle and brake like crap!!!!reason i'm switching the camaro has a special place in my heart and when i cut out the fog light area it's a perfect size for an intercooler as well as it's just meaner looking and a more simpler-if that's a word!(no pop up lights,headlight buffer,vss,etc.)as with the gn it strikes fear into many a vette,mustang and fbody owner!!!i need serious info and advice as this will probably be my last project for a while and will be with me for many many many years.all you moderators that are good at what you do and are not here for any reason other than the sheer infatuation of automobiles thanx for the advice in the past,present and future!!!keep the knowledge flowing!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
87 trans am,gm crate 350(4 bolt mains 10to1),L98 aluminum heads,LT4 hot cam,slp runners,slp 1 5/8 headers,3in.y-pipe,edelbrock base,hi flo cat,air foil,afpr,as&m ported plenum,gutted airbox,t-5 tranny w/centerforce clutch and a 3.27 9bolt(11.9in. brakes),ed wright's fastchip,relocated iat sensor,160 fan switch&t-stat,tb bypass,accel supercoil,cap& rotor,hollowed maf,slp 3in. catbcak.
FOR SALE!FOR SALE!FOR SALE!FOR SALE!FOR SALE!
EVRYTHING IS FOR SALE WITH MY CAR (EXTRA ENGINE,TPI INTAKES,RUNNNERS,PLENUMS,ECM W/CHIP,new springs,aluminum driveshaft.
GETTING OUT OF THE 3RD GEN MARKET BEST OFFERS
CONSIDERED!!!!!!!!!!!
anyonne from new jersey interested??????
Car: Buick
Engine: 231
Transmission: 200r4
I think the brakes on a GN are very good they can hold several (3000) rpm at a power brake and can stop very well. The handling can be upgraded but honestly it takes alot to get one to move like an iroc.You ever hear of Ron's Custom Auto?
g-bodies can pull 1G if set up. There are kits by BAER for brakes and Hotchkis has lots of handleing stuff for them. I'm looking into getting another '79 Monte to replace the one I had for my first car.
-Tas
'89 Formula WS-6
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
To be installed eventually far far far into the future: Yours if the price is right and I don't have to ship
Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248), Catco 3" cat, and injector spacer.
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
-Tas
'89 Formula WS-6
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Super GRK_Taz World
F-Body Dual Exaust
AOL IM: superGRtaz
1 Post
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
I'm thinking get a Regal, swap power plants, sell the regal to get your money back and tweak the turbo plant. Have a poor mans sleeper TTA. Great handling & braking and blow past guys that just can't figure out why you're blowing by them, sucking the paint off of their car, and they can't even hear your engine.
https://www.thirdgen.org/messgboard/...ML/001077.html
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
'86 IROC-Z Camaro
"Cogito ergo zoom"
- 355 cid
- AFR heads
- Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
- modified SLP runners
- TRW forged pistons/ceramic coated
- fully balanced
- Edelbrock headers/ceramic coated
- SLP cat-back
- Paxton supercharger
- Nitrous Express nitrous oxide
anybody knows where someone could get the 3.8 conversion done on the west coast?? NJ is a little far to get an engine swap but the 3.8 are so cool. Or even better, the Pacific Northwest?
Car: 1989 TTA #1240
Transmission: 2004r
do it yourself.i believe the harness is still available as is the ecm.thhe motor mounts you can either get from a junk yard or use 4th gen mounts thhey came wth the 3800 motor from the factory.I've heard with the stock heads the buick gnn motor hits the ac/heater box so you gotta chhange to the front wheel drive Le sabre heads iif you dont change the pistons the new heads will yeild roughly 9 to 1 compression use a thicker gasket to bring it back down
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
I'd do the 3.8.The swap is fairly easy but it is hard to find the parts if you want it done nice.
The TTA harness is still avalable from Caspers electronics for around $600.The TTA motor mounts were unique to the car and are discontinued,but I've heard the GN lower and rubber mounts will work together in a f-car(I'll find out early next week as I slip my motor in for the first time).
Take your time and try to take pics or look over a TTA,it helps give you an idea of how it should be.
HTH,
Steve
1989 Turbo Trans Am's #124 and #850
1989 Turbo GTA,600hp 3.8 SFI TURBO
Banged up 2001 Kawasaki ZX-6R
My Cars
[This message has been edited by TTA850 (edited August 30, 2001).]
HTH,
Steve
My Cars
Mike...94XR7
02-20-2003 07:50 PM
