Window switch necessary for 700r4 & NO2?
I have an automatic 1992 Camaro RS...I have heard all sorts of things, but I figured here I'd hear the real deal. Now, I'm putting a 120 HP NOS kit in my TBI RS, but I've come to understand that it's not a good thing to spray while shifting gears, and a window switch will shut off the nitrous for me so as to save my poor little tranny. Well, what should I do? Where can I get a decently priced one? Thanks!
I've been spraying through the shifts for two years with no problems. Just make sure your tranny's been prepped to handle it. A good shift kit will do the trick. 120 shot on a TBI shouldn't be too much for the 700r4. I didn't start running into problems until I built the motor up, and started spraying 175. Then it started slipping on the 2-3 shift.
TransGo makes the best shift kit. There's a lot of places you can get it from. Try these guys. http://www.pro-built.net/products/transgo.html
I agree with formula on the shift kit. Those guys are awesome. As far as the window switch, I use one to prevent spraying just in case I hit my rev limiter. I set it 300rpm below my rev limiter but it is right above my shift point so that I spray through shifts. I use a 150 shot on my 700R4 with 153k+ miles.
Jeff
Jeff
A window switch will not shut the juice off, unless your RPM's drop enough between shifts. If you want to drop it out between shifts, I would use a button on the steering wheel.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
<font face="Verdana, Arial" size="2">Originally posted by Mark W. Winning:
</font>
</font>
Jeff
Well, what's worth it? I want to spend the least money here; if a shift kit costs less than a window switch, I'll get that, or vice versa. Anyone know where I can get a nice window switch? I just don't want to kill the transmission.
1992 Camaro RS 5.0L
Performance mods
120 HP NOS kit
Flowmaster cat-back exhaust
Hedman street headers
SLP cold air kit
MSD 6A ignition
Audio
Sony Xplod CDX-M610 head unit
Pioneer 2-way 4x6 front speakers
Pioneer 3-way 6x9 rear speakers
12 inch Pioneer VCCS PRO subwoofer
QLogic sealed box
Kicker ZR360 amplifier
1992 Camaro RS 5.0L
Performance mods
120 HP NOS kit
SLP cold air kit
MSD 6A ignition
Audio
QLogic sealed box
<font face="Verdana, Arial" size="2">Originally posted by NavyVette:
Hmmm.. Yes it does. That is the whole purpose of a window switch is to provide a window to operate the nitrous (or anything else) in. It gives you a lower RPM limit and an upper RPM limit. I would never use something that would require me to shut off the nitrous manually on the top end. What happens if you miss the button? or forget to hit it? Making the activation and safety of nitrous all automatic is the way to go. Other than the arming switch everything else should be automatic.
Jeff</font>
Jeff</font>
<font face="Verdana, Arial" size="2">Originally posted by BahamutRS:
</font>
</font>
Jeff</font>
Jeff</font>
<font face="Verdana, Arial" size="2">Originally posted by Mark W. Winning: Jeff, I did not think about setting the upper rpm shutoff to just below my shift point. I guess that would turn it off for a split second during the shifting process. I have mine set 200 above my shift point so the nos will be off in case the motor even heads to the rev limiter.</font>
Formula- I personnely would never use my system manually but if it works for you that's great.
BahamutRS- I would get the safeties for the nitrous operation first but it's ultimately up to you.
Jeff
</font>
</font>
I just trust my finger on the button more than a piece of electronics that can fail. If I screw up, it's my fault. If a window switch malfunctions, a high dollar motor is shot because of a low dollar part.
No problem Jeff, I did not take it as harsh. I just never thought about it the way you did. I just keep thinking that, with my setup, when I shift and my RPMS drop, there are still inside the "window" and the spray is still on. I run my setup the way it is, because I lost a u-joint leaving on the spray on night. The memory tach recalled 9200 rpm! I used a broom to clean up the mess.
1992 Trans Am
05-10-2023 07:19 PM
