Idea about mounting two intercoolers!
What if any advantage would there be to running two small IC for my twin turbo project as say opposed to one huge one like Skulte? I thought i could run the plumbing the same route as Skulte by the head lights and then mount both IC side by side in the front like Skulte and then out the coldside and merge together on the cold side of the IC into one pipe that goes underneath the radiator/frame and straight up and into the intake.
My non-scientific WAG would be that you'd see more of a pressure drop with two smaller ICs due to higher restrictions.
But I'm only guessing here
superiroc,
A properly sized intercooler will have only a very minimal pressure drop, so 2 intercoolers is a good way to go, just expensive, and also remember, every bend in the tubing hurts the velocity,(not volume) so try to make gradual bends whenever possible,
P.S. AFGUN, E-mail me, i live right by ya
maniac@megamania.com
later
larry
MÅN¡ÅÇ ©
88 IROC 5.7L,edelbrock TES,random tech cat,borla exhaust,chip,sfc,accel wires,airfoil,k&n's,ETC..
and NOW supercharged!!!
http://maniac.megamania.com
[This message has been edited by maniacc (edited May 14, 2001).]
later
larry
MÅN¡ÅÇ ©
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
only advantadge i would see is if you intended to use two used coolers, probably from: 89-92 Turbo Probe, 85-89 i belive isuzu impulse, or a DSM, otherwise dont waste money on two coolers instead of one larger one.
Twin intercoolers is usually done due to space limitations (300ZX, 3000VR4, etc.). Pressure drop depends on end tank design, and length of core tubes and boost pipes. The problem with 2 small intercoolers is that you can not get the same cooling effects as having one large single core with long tubes. The charge air is not exposed to cooling air for a long enough time to reduce the air temperature drastically. Use one cooler if at all possible...
1989 T/A, 400" CNC Bow-Tie tall-deck, JE 8.5:1 pistons, Scat H-beam 6" rods, Scat 4340 crank, Crower roller cam, AFR heads, Tiffin Racing sheetmetal intake, Holley 75mm t/b, DFI, variable injector controller, 72# inj., S/X dual-pump fuel system, Hahn Racecraft T76 single turbosystem, NOS 150-hp dry fogger, TH400 w/GV overdrive, Dana 44 w/Detroit Locker and 3.70's, Baer Track brakes, Simmons FR 18X9 and 18X10 wheels, P265 and P285/35ZR18 Nittos, Spohn suspension, Eibach racing springs w/adjustable-height collars, billet camber/caster plates, KYB AGX adjustable shocks/struts, Corbeau Targa RS seats, TeamTech 5-point harnesses, Sparco steering wheel, MacEwen white gauge overlays, Phantom gauges/tach, B&M Pro Stick w/carbon-fiber ****, REAL carbon-fiber dash/console kit (don't ask), S&W 8-point rollbar, Lonza aluminum pedal covers, Pioneer/Boston Acoustics stereo system, filled side markers, Audi fender marker lights, IMSA-style cowl hood (don't ask), custom medium Intense Blue pearl paint, tinted glass. Whew!
Best ET w/383" S-trim: 10.796 @ 125.8 mph
Best ET w/400" turbo, nitrous: Summer 2001
Member of Midwest F-Body Association www.mfba.org
<font face="Verdana, Arial" size="2">Originally posted by Z28racer:
</font>
</font>
the next generation of lien instruments
1992 Pontiac Firebird
- 5.0L V8 TBI
- Automatic Trans
Car: 1989 Formula 350 WS6
Transmission: 700-R4 2600 stall
That, and the fact that all of the cars that are running two intercoolers are also running two throttle bodies. Our twin blade throtte body isn't the same thing. all that air is going into one hole, so why not force it together sooner. Unless it's a single tubo system, in that case, why split it up?
Cody "cyZ28" Young
'84 black on black Z28
355, 5-speed (on the way out. What goes back in, ooohh baby!!)
http://www.geocities.com/mustang_tbird/codypage.html
Cody "cyZ28" Young
If you are looking for an intercooler setup,probably a kit from ati would work.IMO the kit fits well under the nose and is easily routed thriugh the fenders up to the motor,they offer a 3 core,which is 27 inces long about and it fits under the nose easily,plus they offer a sheetmetal one for a bit more
Terrell351
06-13-2021 01:13 PM
Street Lethal
04-30-2019 12:14 PM
toronto formula
11-10-2015 06:17 AM
