Junk Yard Turbos & Mercury wagon in HotRod
Location: Coulterville, IL...Currently on Beale AFB, CA
Did you guys see this thing? He built the engine for about $3000 using junkyard turbo's. It makes 355 rearwheel HP, but with...get this...714 ft/lbs of torque. This big old boat runs the 1/4 in 12.2. Has anyone on this board fabbed up a setup using Junkyard turbos?
Black 89 IROC...Mods: 355, 10.5:1 comp, Big Solid Crower Cam, TFS heads, Victor Jr, Holley, and a 5 spd...12.72@ 116.9 with a 2.16 60ft time on BFG radial TA's
not yet, but the thought has crossed my mind. only problem is that i have no idea where to start if i picked up a turbo. i do have a friend with a V6 86 S10 that is thinking the same thing.
1982 Camaro SC-Z
1982 Camaro SC-Z
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Check the 80's ford SVO turbo 2.3 and the thunderbird/cougar with same engine they have garrett T3's that should work fine for a twin setup.
im starting up a project similar to that,
A 406, Brodix stage II heads,ported and polished, 8:5:1 compression,Accel cam, Victor jr. intake, 1050 Barry Grant carb and Twin turbonetics running at 21lb of boost each, hp should be at 700 and torque at 900.
for cheap DSM turbos (13b, 14b, and T-25s) you can try http://www.dsmtrader.com you can also get intercoolers, BOVs, and other stuff from DSMs cheap there.
<font face="Verdana, Arial" size="2">Originally posted by vortech305:
A 406, Brodix stage II heads,ported and polished, 8:5:1 compression,Accel cam, Victor jr. intake, 1050 Barry Grant carb and Twin turbonetics running at 21lb of boost each, hp should be at 700 and torque at 900. </font>
And it sounds like you are going to try to run 42 pounds total?...good luck is all I can say. I would try running 25-32 and you will find it alot more pump gas friendly and still have the 700 ponies you are looking for..trust me. A guy in chevy H.P. had a LS1 twin turbo on 93/4 pump gas with 35 pounds I think at 985 ponies..and over 1k torque.
<font face="Verdana, Arial" size="2">Originally posted by Camaro_hunter_d:
The TTA's had 7.6 at the most. I would look at 7.8-8.0 at the highest personally.
</font>
</font>
Mike
1989 Turbo Trans-Am
11.25@121.25
Daily Driver
1998 Trans-Am LS1 6 Speed
13.10@106
Slow POS sitting in the Driveway awaiting repairs and then its For Sale. No More V8 Cars for me.
