Willie w/in
1 Post
Car: 2000 Trans Am
Willie w/in
Do you have any pictures of your engine now with the superfueler on it? Im interested to see how that turned out!
-86 IROC
a few mods
this years goal: 10.50 @ 130+ mph
-=ICON Motorsports=-
-86 IROC
a few mods
Car: 1987 Z28 Convertible
Transmission: 5-speed
I don't know that photopoint works any more so I won't attempt to download the image here. Instead, I e-mailed you a pic of the Superfueler and custom airbox (just finished it).
In my e-mail to you, I forgot to mention that the airbox seals against my cowl induction hood, making it a true cowl induction system.
Willie
[This message has been edited by Willie (edited May 03, 2001).]
Willie
Does anyone have any info on that superfueler such as injector size, cost etc?
Willie, how fast are you running now?
Rob
1987 IROC-Z Auto (LB9)
Black/grey interior with the stance of a streetfighter
I like to think of her as Arnold Schwartzeneger in a dinner suit
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat. K&Ns, AFPR and Air foil.
Future mods:
Cam change
New torque converter
New heads (maybe corvette L98)
Strut brace
Sub frame connectors
Ram Air
Current G-Tech times
0-60mph 6.26 seconds
1/4 14.74@100.2mph
Rob
Mods
Future mods:
Cam change
Strut brace
Ram Air
1/4 14.74@100.2mph
<font face="Verdana, Arial" size="2">Originally posted by Guido:
Here ya go!
From my server!
I like it! It looks pretty good man!
</font>
Here ya go!
From my server!
</font>
Awesome.
<font face="Verdana, Arial" size="2">Originally posted by RMK:
Does anyone have any info on that superfueler such as injector size, cost etc?</font>
For more information, request a free Superfueler catalog from Carroll (973.835.1705). It is definitely a neat system with infinite adjustments to trim air/fuel ratios WITHOUT raising fuel pressure. This allows me to retain my stock sized injectors without overkill (killing low-end throttle response) and having to significantly lower my fuel pressure to compensate for larger injectors.
<font face="Verdana, Arial" size="2">Willie, how fast are you running now?</font>
89Procharged,
The Superfueler does seem to function properly even with the long tube runner setup. The plate it uses injects fuel into the plenum in the exact same manner as a plate nitrous system -- which has been proven by many on this board to work great!!
Willie
Willie what kind of a hood are you using to feed that air cleaner? A cowl? or maybe a camaro SS replica.
Also how do you tune the superfueler? does it run off of a computer such as DFI or what?
I've never seen that before and it looks prety cool, it kind of gives you the end result of running the smaller injecters for the regular driving and then open up the 30lb'ers for the big power. Very cool, very streetable. I wsh I had an engine that needed something like that.
<font face="Verdana, Arial" size="2">Originally posted by CanadianBeast:
Willie what kind of a hood are you using to feed that air cleaner? A cowl? or maybe a camaro SS replica.</font>
<font face="Verdana, Arial" size="2">Also how do you tune the superfueler? does it run off of a computer such as DFI or what?</font>
<font face="Verdana, Arial" size="2">I've never seen that before and it looks pretty cool, it kind of gives you the end result of running the smaller injecters for the regular driving and then open up the 30lb'ers for the big power. Very cool, very streetable.</font>
Willie
[This message has been edited by Willie (edited May 04, 2001).]
So do you have any details on how you made the air box?
Your whole set up is done very nicely and I know you've put alot of work into it. Kudos and I hope you get the timeslips you're looking for.
Matt
Matt
Whoops just reread, the fuel curve generator runs off of boost pressure is that correct?
Thanks</font>
Thanks</font>
Willie
<font face="Verdana, Arial" size="2">Originally posted by Matt_91RSTPI:
So do you have any details on how you made the air box?</font>
<font face="Verdana, Arial" size="2">Your whole set up is done very nicely and I know you've put alot of work into it. Kudos and I hope you get the timeslips you're looking for.</font>
Willie
zedder 1 9 9 0
05-30-2001 08:06 AM
