m90 help!!
Old 04-26-2006 | 12:49 PM
streetheatz28's Avatar
Car: 88 Sportcoupe camaro
Engine: forged 355
Transmission: th350
m90 help!!
I have decided to put a m90 on my 87 tpi 305 camaro. The supercharger will set on a plate on top of the right head. The k&N will be at the back of the engine bay and get air directly from the cowl hood. The tubing will go threw a intercooler and back to the tb. I need to know how I need to modify the ecu/fuel. The engine is 100% stock besides flowmaster american thunder cat-back. I want to run around 5psi intercooled. Can I run a fmu and can I keep the stock ecu/chip? Thanks - Charlie
Old 04-27-2006 | 09:27 AM
Drac0nic's Avatar
For what you're doing I'd get a Walbro 255lph in tank and keep an eye out on ebay or similar for a set of Ford Motorsports 30# or 42# FMS injectors. They were used in OEM applications and I've seen em under $200 a set, and they'll give room to grow. I'd run #10 wire back straight from the alternator with a relay for the fuel pump as well.
Buggy Disaster
11-21-2014 12:50 PM
Rezi1987TA
06-28-2012 01:53 PM
Rezi1987TA
12-18-2011 05:07 PM
80smetalfan
09-07-2007 04:57 PM
1983sc
01-22-2007 11:17 PM
Quick Reply: m90 help!!
