10lbs of boost with 100k mile. I'm worried about my head gaskets!
I'm worried my stock head gaskets are going to blow. I have 101,000 miles on a EXCELLENT running car. Check my sig for more info.
Anyone here have a L98/LB9 with a blower with high miles and no head problems?
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL,MSD boost-master,Holley 9mm wires,Ac delco R43ts plugs,custom chip,Ford SVO 24# injectors,Bosch O2sensor, Bosch in-line pump(w/stock pump), SLP 1 5/8" headers,SLP catback,short shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
[This message has been edited by theformula (edited February 25, 2001).]
91 Formula
305 TPI 5speed
1LE/G92/WS6
1 Post
Car: '86 IROC-Z + Misc. project cars.
Engine: Supercharged + Nitrous TPI 355 CID
Transmission: Art Carr built Th700r4
High milage itself should not hurt stock steel shim type head gaskets.
The only way you are likely to hurt a steel shim head gasket is from detonation.
The main thing to look for in a high milage car that can cause problems is oil getting into the combustion chamber. That can cause detonation and the detonation can eat parts.
Tracy /AKA IROCKZ4me
'86 IROC-Z Camaro
"Cogito ergo zoom"
EFI Performance Club on Yahoo
Club IROC-Z
'86 IROC-Z Camaro
"Cogito ergo zoom"
- 355 cid
- AFR heads
- Arizona Speed & Marine hydraulic roller cam w/ AFR hydra-rev kit
- modified SLP runners
- TRW forged pistons/ceramic coated
- fully balanced
- Edelbrock headers/ceramic coated
- SLP cat-back
- Paxton supercharger
- Nitrous Express nitrous oxide
Club IROC-Z
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
<font face="Verdana, Arial" size="2">Originally posted by theformula:
</font>
</font>
Engine: 355
Yo Wraith, how many times has your paxton been rebuilt? Just curious</font>
Car: 2018 Camaro SS
Engine: LT1 w/Paxton 1500SL
<font face="Verdana, Arial" size="2">Originally posted by TheWraith:
i've only owned it since fall.. the previous owner had it rebuilt once, i don't know of the history from before that.
</font>
</font>
Originating member of the SJNEP Crew
Rice..It's whats for dinner!
All new projects put on hold till its fixed..whenever that is
Check out MyGTA
***AOL IM RiceEatinGTA***
Tony
why do they have to be rebuilt? i dont know anything about SC's so dont flame me. i am looking into a VORTECH or an ATI but i am not sure yet. thanks jarrad
1990 IROC-Z L98/G92 350 TPI
too much to list!!
5,507 IROC's; 2,415 5.7L IROC's Produced in 1990
Dare to be DIFFERENT,
DAILY DRIVER: 1991 S10 2.5L/5SPD WITH CAMARO RIMS
MUSTANGS...ONLY 4 LUGS....HAHA THAT IS HILARIOUS.
too much to list!!
Car: 2018 Camaro SS
i'm going with an ATI when i go with a blower...vortech makes a damn good blower too
[This message has been edited by fly89gta (edited March 07, 2001).]
I have a paxton sn2000 with 8lbs of boost and mine has run fine for the past 1 1/2yrs. I put about 10K on the s/c but i hear of people having to rebuild them? I do have an oil cooler so I'm sure that will help a little. Like I said, I have had no problems with it (knock on wood!) but i would like to know what sighns to look for in a unit that is going out. Any info would be greatly appricated!!! The only reason i pruchased a paxton was because they are very quiet and i had to sneek it in the car with out my wife knowing.....wish i would have purchased an ATI!!
craiger
craiger
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Man I have to get in on this. I put a Paxton SN93 unit on my show truck www.bharris.org/92GMC and changed the oil religously at 3k or less and it blewup about once a year at about 10k miles. I never pushed it above 5k rpms. I even had an oil cooler on it once until it blew up and melted down the external pump on the way to a show . Blew burn trans fluid all over the hood. As far as performance gains. You only get boost from about 2500 up. No bottom end power at all. I sold my last Paxton unit (since they covered every other one under warranty) off and I have been in the process of building my 350 5 speed to achieve the same horsepower but with a much better power curve. Just blowing off a little steam. I wouldn't have another paxton if you give it too me.
ambainb
04-25-2016 09:21 PM
355tpipickup
08-27-2015 08:13 AM
NinjaNife
08-23-2015 11:49 AM
