Are BOV's really important?
#51
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Originally Posted by FbodTrek
Pluck it straight from a 1st generation DSM (Talon, Laser or Eclipse turbo), they are good to about 15 psi STOCK, and are known as the best production bypass valve ever made. You can "crush" them to hold about 25 psi as well. It's what i run, as well as thousands of other homebrew turbo guys. ![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
#52
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
JUNKCLTR,
I bought and installed the 710n.
Do you know how muhc vacuum it needs to open?
it seems as if it's not opening, becasue i'm still real rich at idle..
also...do you have a pic of the direvtion of flow for this valve? maybe i have it backwards/
#53
1 Post
Engine: 3xx ci tubo
The link I posted in this thread on June 20 of this year shows the amount of opening per vacuum. It also shows the direction of air flow.
Right before you go into boost you will hear a lot of air being returned to the air cleaner. That would tell you if it is connected properly also. When in boost it quiets down and the turbos start to make noise. I did not measure the opening vs. vacuum.
#54
the main difference between a blown car and a turbo car when it comes to bypass, is that the blower is ALWAYS making boost.......so its hugely beneficial to the system to have an open bypass for part throttle driving and no load conditions.
depending on how big the blower is, there can be a truly massive amount of air moving through the system at WOT/redline under load.......if you snap the throttle shut without a bypass and the tubing holds together you can blow gaskets, or worst case scenario even bend the throttle blades.
adding the bypass was one of the most important driveability developments with centrifugals. And as far as the entire "who lifts to shift anyways?" argument......everyone does.....if you powershift your car driving to the store you have mental problems
#55
PS......there are alot of guys running F series prochargers that are using 2 of the huge atmospheric bypasses now......even with my f1R the pressure inside the hat with the bypass open and the car in neutral hits 15psi above the throttle plates
ZZ3Astro
08-13-2019 12:57 AM
