Can Cast Pistons take the abuse?
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I have built an impressive budget engine out of of a 92TBI short block and vortec heads, but now that Im questing for more HP and thinking about the squeeze I'm a little curious how well the cast pistons and stock rings and all will hold up to the nitrous on top of the power Im making already. The only thing replaced on the short block was the bearings and the engine has about 35K total miles........No more than 100HP would be used if I opted for the bottle
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
13.24@104
1 Post
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
If you stay at or below 100HP it will live fine for a long time.Make sure that your ignition and fuel systems are in top working order.
Superman
Rev'n to Seven
Superman
Rev'n to Seven
Car: 1986 Firebird
Engine: 2.8 V6
Slick! I was coming here to ask the same question. I'm thinking of rebuilding my 2.8, and was considering adding nitrous in the future. I noticed how much more expensive forged pistons are- and decided "Hey, why put that $$ into a v6?" Good to know I could run with cast pistons and still use nitrous oxide.
Basically as long as your fuel pump's good, nothing bad can happen to a piston, right? I replaced the pump myself in July of 1997-- July 5th, actually. What a crummy holiday weekend that was!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
I have ran 150 shot for over three (yes, 3) years on a completely STOCK engine L-98 (350). Love it too. It will hold it as long as your timing and fuel are correct. If not ......oh no
92 Z 350 A4
N2O, EDELBROCK, MSD, K&N,FLOWMASTER,CRANE,
1/8, 7.96@85.69 60' 1.66
92 Z 350 A4
I have done the same thing.. I have run several cast piston motors with a 125 or 150 shot for years and never had a problem.. I even have a 2 bottle a week habbit..lol. My last one was in my Nova and it was a cast flattop piston 350 with a 280 type hydrolic cam, stock 882 heads, a performer intake, headers, 2 1/2" duel exhaust with flowmasters, 4.11 gears, and a TH400 with a 3000 converter and ran 8.1's in the 1/8 which comes out to a mid 12 in the 1/4. I drove this car daily to and from work and to and from the track. It was very fun and never had a single problem.
LT1Formula
10-08-2015 08:34 PM
skinny z
10-05-2015 06:23 PM
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
