Strongest Cranks??
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
Strongest Cranks??
Im looking for the strongest crank to go with my 350 with 16 psi and 8.5-8.7:1 comp.
I know I need a forged steel crank but does anyone recommend any brands?? also suggestions on the con. rods and pistons would help.
aka:15 year old camaro freak
owner of a 91 z28 5.7l camaro
Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Trans Go Shift Kit, 2k Stall, B&M Rachet Shifter, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
more to come....
My 91 Z28
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Don't forget Callies......
GTA -89:Free flow muffler,dual 3" HF cats, Edelbrock headers, Vette heads, 1.52 RR 7/16, ZZ-9 cam, Big Mouth, AS&M LTB, ported plenum, 52 TB, MSD 6AL, TPIS level V prom, Mod .MAF, Superior shift-kit and some minor mods. and more to come!
http://www.itv.se/tacs/members_cars/m279/m279.html (Swedish Trans Am Club)
1 Post
Car: 2000 Trans Am
Eagle also sells good stuff at a decent price. Im betting not as good as a cola, lunati or callies crank but your not breaking the bank either.
Good luck.
Good luck.
Car: 1991 Z28
Yea I was looking at Lunati (expensive) Is there a catalouge for cola cranks??
Car: 1991 Z28
Also what about Scat cranks are they good?
people have been using eagle name brand in 1000hp + applications without breakage, if so it had been their fault. many in the nmra run it without problems. i am using a eagle rotating assembly when i get around to it.
skinny z
10-05-2015 06:23 PM
